nilson Posted August 8, 2011 Posted August 8, 2011 hello want someone to help me, I have the Extended LDD enabled to have more variety of parts, but I'ma fan technic builder, I started my adventure building the Ferrari 599, but I stopped when I realized that some pieces had not the ldd, utlizando try other programs like MLCAD and LeoCAD but frankly are disgusting, I have tried everything but still I have not the room, the worst news is that if you have MLCAD and I open it when you export it, anyone can help by Please attach a picture here of the pieces that I could not find, I hope some response .... thanks Quote
Calabar Posted August 8, 2011 Posted August 8, 2011 LDD is a closed software, I think there will ever be bricks that will be not included in its database. You could try another software, SR3D Builder, that uses LDraw 3D models in a 3D interface (similar to the LDD one). Quote
DLuders Posted August 8, 2011 Posted August 8, 2011 @ nilson: Welcome to Eurobricks! hrontos made some LDD Shock Absorbers on this Eurobricks post. Quote
nilson Posted August 8, 2011 Author Posted August 8, 2011 LDD is a closed software, I think there will ever be bricks that will be not included in its database. You could try another software, SR3D Builder, that uses LDraw 3D models in a 3D interface (similar to the LDD one). I also try n run on the computer it says that I require a graphics card, I remember that when you apply the extension to my ldd so it we said something that would update slowly the pieces there any truth to this? The truth is that I find another program like ldd have such a great option to put the pieces together as to form magnetic structure does not lose its geometry, the MLCAD I and distorts much more than I spend hours trying to put all well-fitted pieces and after a few pieces start to notice a mismatch, the same happens to me with ESWL answer? please Quote
Calabar Posted August 8, 2011 Posted August 8, 2011 I have some problem to understand you (English is not my native language). Could you write it again in a clearer way? Thanks! Quote
xSergio74 Posted August 9, 2011 Posted August 9, 2011 I also try n run on the computer it says that I require a graphics card, I remember that when you apply the extension to my ldd so it we said something that would update slowly the pieces there any truth to this? The truth is that I find another program like ldd have such a great option to put the pieces together as to form magnetic structure does not lose its geometry, the MLCAD I and distorts much more than I spend hours trying to put all well-fitted pieces and after a few pieces start to notice a mismatch, the same happens to me with ESWL answer? please Hi, if you are able to run LDD, you should also be able to run SR3DBuilder on your computers since graphics requirements are nearly the same. Please let me know some details on your graphic card and I try to help you. Also ensure to follow the instruction on SR3DBuilder download page to install application pre-requisite and let it work the correct way. You can also private email me if you want... byes Sergio (author of SR3D Builder) Quote
