i like this truck, but i havent had a chance to build the trailer, i dont think i will build it any time soon.
i added the motor to the inside of the truck to power the engine, but not the wheels, but this was the intention. then i added the battery box to the rear and then added a cover to the back of the truck.
this is my first modification to a technic model
100_7311Large.jpg.
the battery box is controlled by the axle sticking out the top at an angle, i have also mounted the front wheel turner a little higher, but there is some friction when turn the wheels due to the proximity of the battery box
Edited by Seluryar
i have gone and made a few alterations.
turned the battery box around for easier access. and i have added 2 universal joints to the axle from the motor to the engine as one of these images will show that theres an angle between the motor and engine
sorry about the quality of this last image but it still shows the angle
this modification was using only pieces from the set it came in
made a little trailer for this truck, started out with the instructions, but then turned away from them within a few steps.
again, i only used pieces that came with the set.
@ Seluryar: Your 8258 Alternate Build has nice, clean lines! It is an attractive, colorful combination. :thumbup: The truck looks better than the standard, 8258-2 "B-Model" does (see pictures below):
Did you alter that little blue car on the trailer too, or is it a standard 8214 LEGO Racers Gallardo LP560-4 Polizia models exclusive to Toys-R-Us?
Edited by DLuders
Seems like the regular one. I just roughly counted studs width on the trailer (~15 studs) and lambo is (~14 studs).
Pretty cool creation!
added a gear to the axle that goes from the motor to the engine to catch the existing gear below it from the original model so that the wheels move as well as the engine pistons.
as i have done this, i noticed that it is possible to strip some gears, so i have raised the rear wheels off of the ground so that the model can stay in place while being operated.
i wish to purchase whatever is needed to make it remote controllable
