Milan Posted October 9, 2010 Posted October 9, 2010 i agree. next i will test this combination. if you and i right, it will lift my trial truck easier It will lift it easier, for sure, but visually it is uglier because the motor is on the side of the cylinder. Quote
legolijntje Posted October 9, 2010 Author Posted October 9, 2010 the motor will not be at this place But, where? Also; great construction! Quote
efferman Posted October 10, 2010 Posted October 10, 2010 it sits here First lifting Tests are showing that it is extremely slow but powerfull. If no internal LA Clutch is slipping, the M- motor has no problem with 1Kg at the end of a 42 studs long boom, when it is horizontal. at a higher angle the lifting capacitiy will be better. If only one clutch is slipping , the LAs will cant and the resistance will raise to block in extreme cases. It is important that you have four LAs with the same clutch resistance or else it will not work properly. But i think this problem have all combined actuators which are side by side. Quote
efferman Posted October 10, 2010 Posted October 10, 2010 thanks ia have made a little video of a little Lift Quote
dolittle Posted October 10, 2010 Posted October 10, 2010 thanks ia have made a little video of a little Lift The cat sounds worried :) In any case, cool! Quote
efferman Posted October 10, 2010 Posted October 10, 2010 The cat sounds worried :) In any case, cool! hehe, the cat is always begging for hugging Quote
