roamingstop Posted May 30, 2010 Posted May 30, 2010 (edited) Quick Question. I recently got a job lot of Technic pieces; and it included this (photo). It is labeled Lego 1-01... but I cannot identify it on Peeron or Bricklink (probably the wrong keyword). Does anyone know where it comes from, and what pieces mate with it? I thought perhaps it was an engine cylinder (does not fit) or something from a suspension unit (no relevant photos). Thanks, RS Edited May 30, 2010 by roamingstudio Quote
Jurgen Krooshoop Posted May 30, 2010 Posted May 30, 2010 (edited) No I've never seen those before, but I'm just as curios as you. Edited May 30, 2010 by Jurgen Krooshoop Quote
backbone Posted May 30, 2010 Posted May 30, 2010 http://www.bricklink.com/catalogItem.asp?P=2790 Used for steering with: http://www.bricklink.com/catalogItemPic.asp?P=2791 and http://www.bricklink.com/catalogItem.asp?P=2792 Steering build with these parts: Quote
roamingstop Posted May 30, 2010 Author Posted May 30, 2010 Thanks guys... solves one little mystery! Quote
Plastic Nurak Posted May 30, 2010 Posted May 30, 2010 I bet you're very very young to not know this piece . (jokin') Quote
BobaFett2 Posted May 30, 2010 Posted May 30, 2010 I think I've used the piece in a 2005 set. (The car, "tractor") Quote
backbone Posted May 30, 2010 Posted May 30, 2010 I think I've used the piece in a 2005 set. (The car, "tractor") And in late 90's i remember ;P Quote
roamingstop Posted May 30, 2010 Author Posted May 30, 2010 I bet you're very very young to not know this piece .(jokin') Actually I'll have you know I've been 7 five times now. Quote
CP5670 Posted May 30, 2010 Posted May 30, 2010 This piece (and the two other steering parts that went with it) was used in almost every small set in the 90s. They formed a simple rack-and-pinion steering assembly. I haven't found many uses for these things outside of that though. Quote
Plastic Nurak Posted June 1, 2010 Posted June 1, 2010 I think I've used the piece in a 2005 set. (The car, "tractor") ---> No. Quote
phool Posted June 1, 2010 Posted June 1, 2010 This piece (and the two other steering parts that went with it) was used in almost every small set in the 90s. They formed a simple rack-and-pinion steering assembly. I haven't found many uses for these things outside of that though. Indeed, many fond memories of putting that steering system together for the simple MOCs I'd make as a youngster. Quote
Blakbird Posted June 1, 2010 Posted June 1, 2010 That piece came out in 1988. You can read a bit more about it here: http://www.ericalbrecht.com/technic/1988.html#Parts Quote
Plastic Nurak Posted June 5, 2010 Posted June 5, 2010 Indeed, many fond memories of putting that steering system together for the simple MOCs I'd make as a youngster. Yes, me too . Quote
