Jurgen Krooshoop Posted April 19, 2010 Posted April 19, 2010 (edited) As noticed earlier by dluders, I've created a new gearbox. (maybe an admin wants to join these 2 topics to keep the forum tidy). For some time I wanted to make my own remote-controlled reliable gearbox with more than 2 speeds. I've seen some nice designs, like Sariel's aeroshift and Sheepo's 7+R gearbox, for which I've had the honour to make building-instructions. See mine in action: name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">There were a number of important aspect: * Reliable drivetrain * Preferably 4-speeds * Being able to switch gears with a single motor * No pneumatics Like in Sariel's design, the transmissions consists of identical modules, where each module has 1 driving-ring and adds 1 gear. All the gear-ratios are identical: 5/3 from 1st to second, 5/3 from 2nd to 3rd and 5/3 from 3rd to 4th. The total amount of gear-reduction is about 4,63. By using the 24-8-tooth gear combinations (instead of 12-20), ratio's of 3/1 can be achieved. For effeciency-reasons, the gearbox only reduces speed, the highest gear is actually neutral (same speed coming out as is coming in). Also for the efficiency, the module(s) with gear-reduction are located nearest to the input. This way the dead gears have less effect. The switching systems was inspired by Sheepo's gearbox, but I wanted to use the ridged axle-joiners insted of the smooth ones Sheepo used. This way the driving-rings would stay in place better, contributing to a more reliable drivetrain. This gearbox will be used in my new supercar, with which some succesful driving tests have been done. I plan to expand the desing with some kind of stepped motor to improve the swithing-system, but for now it works quite nicely. I've made complete step-by-step building instructions so you can include this gearbox in your own designs. You can download them in my brickshelf-folder. All comments & suggestions are welcome. Edited April 19, 2010 by Jurgen Krooshoop Quote
DLuders Posted April 20, 2010 Posted April 20, 2010 This gearbox will be used in my new supercar, with which some succesful driving tests have been done. The 4-speed RC gearbox looks great! Do you have to modify your existing "Wasp" Black Technic Supercar ( http://www.brickshelf.com/cgi-bin/gallery.cgi?f=412228 ) to make a 4-speed transmission? It sure is packed with gears already: Quote
Jurgen Krooshoop Posted April 20, 2010 Author Posted April 20, 2010 The 4-speed RC gearbox looks great! Do you have to modify your existing "Wasp" Black Technic Supercar ( http://www.brickshelf.com/cgi-bin/gallery.cgi?f=412228 ) to make a 4-speed transmission? It sure is packed with gears already: No, I won't be modifying my "Wasp"-supercar (it's been disassembled more than a year ago....). I am making a completely new car with will feature this gearbox. Quote
