Cwetqo Posted October 31, 2010 Posted October 31, 2010 (edited) I modified it according to this instructions and it works, but not perfectly, so I plan to re-do it in a simpler, more effective way. The problem is that the designer had (in order to keep fake piston engine) routed the drive for steering motor around whole back of the excavator, through several universal joints and gears. Drive from motor is direct, so all those joints and gears move at full M-motor speed. Drive is also too high for linear actuator to effectively fold the excavator (which takes a lot more power than normal steering) and even if it does it it's fast for precise steering. LA also has too limited horizontal movement freedom and it bumps into surrounding beams too fast (I fixed that with small modification). I also tried building version without LA, but It didnt work at all, because M motor directly drives worm gear which turns 24T gear and folds the loader. Because less than 90 degrees rotation of this gear is needed for full side to side turn, the gear ratio is again too high for the system to work. 4 wheel drive works ok, but it's a little to "jumpy", because XL motor is attached directly to diferential (without any gear reduction). After it manages to move it's ok, but again too fast and too hard to steer (because of above mentioned problems with not enough geared down LA). I solved this partialy with variable speed remote control, but since its meant for trains it's too difficult to control, so I plan to remove fakes piston engine and install gear reductions for both driving and folding motors. XL motor is also mounted without proper fixation (probably because of intention to use as much original parts as possible) and it tends to loose it's surrounding beams after few "jumpy" starts, which causes gears to skip. I fixed that with use of large "T" shaped 1/2 width beams instead of originaly planned small "L" beams. Both lifting functions work flawless and it's really fun to operate them simoultaneously. Please dont get me wrong: instructions for motorization are great and I really admire the designer which managed to put in additional two M-motors and even one large XL motor and kept all main parts of original model. But to achieve this he had to make some compromises which make operating the model a little to difficult (at least for me, some of you might have different impressions) "Folding" LA and motor above differential: Modified beams to give LA more space (it moves left/right when it folds the loader and in original design this "L" beam was one beam width closer to it and LA bumped into it too soon) Drive for "folding" LA: from M-motor, through two U-joints, onto three 16 tooth gears: To the other side, again thru two U-joints finally to folding LA. Too complicated and too direct. Front motor is very well integrated: The other two M-motors lay side to side with folding LA in the middle of loader (just bottoms can be seen here). Finished model looks exacetly as original model and it's really hard to beleive that all those motors were added. It look and works really great with 8275 and 8403 in its great fun to have whole "construction site" fully RC powered. Edited October 31, 2010 by Cwetqo Quote
jantjeuh Posted October 31, 2010 Posted October 31, 2010 Thanks for the information :) I had already figured out that it would be easy to add a XL motor in the front to drive the differential directly, but I was still wondering how to add the three M-motors for steering and lifting/tilting the bucket. I have plenty of ideas now.. Quote
jantjeuh Posted November 5, 2010 Posted November 5, 2010 Just built the B-model, it's nice as well. 8265 is really an excellent set Quote
Out of Sight Posted January 16, 2011 Posted January 16, 2011 (edited) Guys, sorry for bumping up old thread, but I'd just finished building my 8265 (will be PF-ed soon) and noticed I have two extra gears left. A 20t bevel gear (tan) and one worm gear. I had gone through each steps to see if I missed anything..but none to my knowledge. The only use of a tan 20t bevel gear is on the front LA for the bucket. Worm gear..remains a mystery. Is there any particular use of these leftover gears on the stock model, or are they just mere 'extras'? Thanks Edited January 16, 2011 by Out of Sight Quote
Benly Posted January 16, 2011 Posted January 16, 2011 Guys, sorry for bumping up old thread, but I'd just finished building my 8265 (will be PF-ed soon) and noticed I have two extra gears left. A 20t bevel gear (tan) and one worm gear. I had gone through each steps to see if I missed anything..but none to my knowledge. The only use of a tan 20t bevel gear is on the front LA for the bucket. Worm gear..remains a mystery. Is there any particular use of these leftover gears on the stock model, or are they just mere 'extras'? Thanks The worm gear might be used for the grappling claw of the B model. Quote
mx2000 Posted September 27, 2011 Posted September 27, 2011 Thanks for the review! Just picked this set up for €49 at a local retail store - it was their last unit, stuffed between boxes of more recent models. They obviously wanted to get rid of it, and I happily relieved them of their burden Really looking forward to building this. My last big Technic model was 8479 Barcode Truck, so its been a while... Quote
trekman Posted September 27, 2011 Posted September 27, 2011 Thanks for the review! Just picked this set up for €49 at a local retail store - it was their last unit, stuffed between boxes of more recent models. They obviously wanted to get rid of it, and I happily relieved them of their burden Really looking forward to building this. My last big Technic model was 8479 Barcode Truck, so its been a while... You'll really enjoy the build. It is especially worth it at that price. I think it is a shame that some toy shops hold out on full price on models going back 18 months or more. Quote
Tazio Posted September 28, 2011 Posted September 28, 2011 This was my second set after the 8051 & a 20 year+ dark age...I was speechless when I was in half the building process, it really is fun to put together. Quote
mx2000 Posted September 28, 2011 Posted September 28, 2011 Just finished... very nice build. I'm probably going to get the motor, moving the bucket manually gets old fast. The steering seems kind of stiff - I find it much easier to just grip the loader by the cabin and steer by applying some rotational force. This was my second set after the 8051 & a 20 year+ dark age...I was speechless when I was in half the building process, it really is fun to put together. It's my second set too - I bought Mindstorms a couple of weeks ago and have been hooked since (I also learned that NXT motors are nice, but also huge and very hard to integrate into normal models ...). Quote
Paul B Technic Posted September 28, 2011 Posted September 28, 2011 I have always loved this set and would love to get another one of them soon. Quote
CisFran Posted January 13, 2013 Posted January 13, 2013 I started to build this model tonight(my first technic model assembly), just finished the 1st booklet instruction...I'm excited to finish the model! bought it for about $80 (on sale in a toy store)...I wonder what's the price they were selling it when it was issued before.. Quote
Kronos Posted January 13, 2013 Posted January 13, 2013 bought it for about $80 (on sale in a toy store)...I wonder what's the price they were selling it when it was issued before.. www.brickset.com lists the original retail price as $79.99 USD/74.99 BP Quote
CisFran Posted January 13, 2013 Posted January 13, 2013 (edited) www.brickset.com lists the original retail price as $79.99 USD/74.99 BP thanks! atleast I didn't pay a premium for those hard to get discontinued sets.. I checked on eBay and bnew sets goes for about $150-$200 nowadays Edited January 13, 2013 by francisalmario Quote
Kronos Posted January 13, 2013 Posted January 13, 2013 thanks! atleast I didn't pay a premium for those hard to get discontinued sets.. I checked on eBay and bnew sets goes for about $150-$200 nowadays Yeah! Great find. I'm still looking for one. Quote
The_Skirrid Posted January 14, 2013 Posted January 14, 2013 Kronos, try Frome Model Centre. I don't know if he posts internationally, but mine shipped yesterday at RRP Give him a ring, might be worth it. Disclaimer: he's nothing to do with me, but I use him for 82xx series kits, as he's always a year behind with sets, and has plenty. Quote
CisFran Posted January 24, 2013 Posted January 24, 2013 @ jantjeuh: Here's a outlining Sarafiel's instructions for motorizing the 8265 Wheel Loader: Hi DLuders, Sorry to ask an old question but what is the difference between the two RC modifications, #4 or #5? And which is the best between the two? thanks! Quote
Alasdair Ryan Posted January 24, 2013 Posted January 24, 2013 (edited) Well I have just bought the loader from a member on eurobricks,I will be motorizing mine too. The difference between the two kits is that one uses worm gears to steer and the other one uses La's. ( I am building the La steering version) Edited January 24, 2013 by Alasdair Ryan Quote
CisFran Posted January 24, 2013 Posted January 24, 2013 (edited) Well I have just bought the loader from a member on eurobricks,I will be motorizing mine too. The difference between the two kits is that one uses worm gears to steer and the other one uses La's. ( I am building the La steering version) thanks! so it must be the LA version the better of the two Edited January 24, 2013 by francisalmario Quote
Cwetqo Posted January 24, 2013 Posted January 24, 2013 Yes, it is, I built first version with worm gear and it was not performing well. LA version steers nicely, but problem remains in too high transmission ratio from XL motor. So loader is too fast and not powerful enough. But this is true for both version of this modification. I have plans to remove fake motor and incorporate gears for reduction of speed. Quote
Technic Gearhead Posted January 24, 2013 Posted January 24, 2013 A slightly larger, fully RC'd flagship-style version with 9398-sized rolling stock might be in order. A little extra space might help in resolving some of the current dislikes. I would love to see one from TLG next year. Quote
