Paul B Technic Posted 12 hours ago Posted 12 hours ago Designed By DamianPLE Technic Garage The LEGO Technic 42213 – Ford Bronco is a solid set in its own right, but this C model Unimog designed by "DamianPLE Technic Garage" takes it to an entirely new level. It captures the rugged utility of the classic Unimog in a compact scale, with a surprising number of working features packed into the build. Functions Openable hood – Reveals the V6 engine detail inside. Working V6 engine – Driven by the rear wheels, adding a realistic touch. Steered front axle – Smooth and effective, though placement is key during the build. Working suspension – Both front and rear axles have suspension, giving it great playability. Tipping cargo bed – A small but effective mechanism that really makes it feel like a functional work truck. Build Experience| The build process was mostly smooth, but I did encounter one hiccup at step 22. I accidentally placed the 2L beam with axle hole the wrong way around, which left the steering inoperable when I completed the model. Thankfully, after going back over the instructions, the error was easy to spot and fix. Once corrected, everything worked flawlessly. Final Thoughts I am a huge fan of this model. It’s an excellent C model that not only looks amazing but also fits perfectly within a building and construction theme. While it is quite a bit smaller than LEGO Technic’s iconic 8110 Unimog U400, this doesn’t take away from its charm or play value. In fact, I see this as an ideal base for future modifications and custom Unimog-style attachments. Overall, I actually think this build is better than the official A model. It combines looks, functions, and modding potential into one compact package. I’m really looking forward to making good use of it as a platform for some creative upgrades in the future. Verdict: Highly recommended – a brilliant C model that punches well above its weight. Left Over Parts https://paulbtechnic.blogspot.com/2025/08/review-lego-technic-42213-c-model-unimog.html Quote
