ok here's the scenario:
on the level where you have to face darth vader in cloud city in free play, at the carbon freeze chamber, there is supposed to be a mini kit in the middle when you use a sith guy to unlock something with the dark force, but it isn't there :thumbdown:
HELP PLEASE!!
btw it is on gamecube
thanks
This isn't a glitch, I had trouble with this one too.
Just gonna bullet, hope thats ok
  • Defeat Vader in that room
  • Build with the bricks that fall to the floor
  • Use dark force on lever
  • Enter crane that you built with the pieces
  • Move the crane over to the two stormtroopers shooting at you and pick them up one at a time, dropping each one into the carbon freezing thing that opened up in the middle
  • Peices will appear, build them to get the minikit
I did mine on PC, but it should be the same.
Hope I helped
I had this problem as well, also on PC. It kept not working, then suddenly one time it did. I didn't do anything differently, it just worked. So I'd just suggest you just keep trying and it'll work eventually.
ok the first time i played that level, i got all minikits, finished the level and it auto saved. then i went to the cantina in front of that door and it said i only got 5/6 minikits. so i turned the minikit detector on and played it again and it said the minikit was in the carbon chamber place but it wasn't there when i did all the stuff required
You dropped both stormtroopers into the hole like I said? The hole will start steaming and then a bunch of pieces will pop out. Build them to get the minikit.
yes :cry_sad:
