ExeSandbox Posted May 12, 2025 Posted May 12, 2025 (edited) Hi Eurobricks! It's been a while since I've posted a MOC here. This project has been on my mind for a long time and also especially inspired by the amazing Fiesta Balloon by RoxYourBlox. My balloon is much smaller of course. The clouds serves to balance the top-heavy balloon physically and visually (an idea that started from an old MOC of mine years ago), while the seagulls adds a little more dynamism to the model. (This model has also been submitted to the Bricklink Designer Program Series 8: https://www.bricklink.com/v3/designer-program/series-8/2894/Hot-Air-Balloon) The clouds has a well in the center to cradle the balloon basket Some size comparisons to existing hot air balloons in LEGO sets. I wish the prefab balloon shells comes in many more colors, but until then we'll just have to make do with a fully brick-built one. Geeking out a bit on the construction of the balloon. A lot of time was spent trying to solve the internal structure to ensure the model can be picked up and swooshed around. Beginning with the basket and neck of the balloon supported with a central axle and four perpendicular rods. The lower ring of the balloon required an angle of 37 degrees for the wedge plates to sit flush together with no gaps. This part took many iterations before landing on this solution. For the central ring there are no angles involved, just a regular snot connection. The 6x6 round plate is vital to prevent gravity from pulling apart the assembly as the outer panels are quite heavy. The upper rings uses a basic clip/bar connection and are also supported by a 6x6 round plate. In the end, this is the assembly with the outer panels attached. Just have to repeat everything 7 more times... Side note: A new 2x2 circular bar frame has been introduced by LEGO very recently and it just happens to be PERFECT part for this hot air balloon. With this there is no need for the tedious process of aligning all the clips on the old 2x2 octagonal bar frame and the clips can't be easily detached sideways too. Unfortunately I couldn't get my hands on it as it is still rare on the aftermarket so I had to stick with the old 2x2 octagonal bar frame for now. I'm looking forward to trying these out when I can get my hands on them. Edited May 12, 2025 by ExeSandbox Tweaks to the links Quote
Feuer Zug Posted May 12, 2025 Posted May 12, 2025 Excellent hot air balloon. I love the expression on the minifig. Quote
baublitz Posted May 14, 2025 Posted May 14, 2025 So nice to see an original design that captures the form without using those large moulded pieces. Looks amazingly sturdy, too. Very well done. Quote
Yoggington Posted May 14, 2025 Posted May 14, 2025 This is a beautiful build. I would go so far as to say the best at its piece count in the current BDP. Seeing the inner workings and the planning you had to put in is making it even more appealing. If you don't make the cut, I'll be happy to purchase instructions. Quote
hikouki Posted May 15, 2025 Posted May 15, 2025 I really like how you captured that shape so well. Quote
Ptchnk Posted May 15, 2025 Posted May 15, 2025 (edited) 15 hours ago, Yoggington said: This is a beautiful build. I would go so far as to say the best at its piece count in the current BDP. Seeing the inner workings and the planning you had to put in is making it even more appealing. If you don't make the cut, I'll be happy to purchase instructions. +1 This MOC is such a nice built and is simply enjoyable to look at. I really like the vibe it's bringing. Add to this the building experience. I would definitely buy this set for me and as a gift. Edited May 15, 2025 by Ptchnk Quote
Lyichir Posted May 15, 2025 Posted May 15, 2025 This is quite lovely! The solution you've come up with for the balloon construction is quite complex but the end result is beautifully seamless. Quote
ExeSandbox Posted May 15, 2025 Author Posted May 15, 2025 On 5/12/2025 at 10:14 PM, Feuer Zug said: Excellent hot air balloon. I love the expression on the minifig. Thank you! On 5/14/2025 at 8:16 PM, baublitz said: So nice to see an original design that captures the form without using those large moulded pieces. Looks amazingly sturdy, too. Very well done. Thank you! I was pleasantly surprised the regular wedge plates worked so well to form the balloon shape. 18 hours ago, Yoggington said: This is a beautiful build. I would go so far as to say the best at its piece count in the current BDP. Seeing the inner workings and the planning you had to put in is making it even more appealing. If you don't make the cut, I'll be happy to purchase instructions. Thanks! That's a huge compliment for me. Will defo be putting up instructions if it doesn't make the cut. 2 hours ago, Ptchnk said: +1 This MOC is such a nice built and is simply enjoyable to look at. I really like the vibe it's bringing. Add to this the building experience. I would definitely buy this set for me and as a gift. Thank you! I'm really glad to hear that. I try to emphasize a certain vibe for my builds. 2 hours ago, Lyichir said: This is quite lovely! The solution you've come up with for the balloon construction is quite complex but the end result is beautifully seamless. Thank you, I appreciate it! Funnily, the current balloon construction is the simplified version, earlier iterations got very out of hand. Quote
Max_Lego Posted May 19, 2025 Posted May 19, 2025 This looks absolutely splendid. The shape is perfect, and it's so nice of you to demonstrate how it was built! Great thanks! Quote
LettuceBrick Posted May 20, 2025 Posted May 20, 2025 Very nice SNOT and angle work for an excellent result. And very nicely documented too! Quote
Yoggington Posted June 14, 2025 Posted June 14, 2025 Congrats on the selection, very well deserved! You've made one sale here at least, I'm sure there will be many more. Quote
Elysiumfountain Posted June 23, 2025 Posted June 23, 2025 Congratulations on the win! I knew it was going to make it the minute I saw it! :) Quote
