codyaner Posted May 5 Posted May 5 The RZ-1 A-Wing Starfighter is a sleek, high-speed interceptor used by the Rebel Alliance during the Galactic Civil War. Known for its agility and powerful twin laser cannons, it was a key part of many hit-and-run attacks and space skirmishes. This version features the distinctive Blue Squadron color scheme, making it a unique addition to any Rebel fleet. This MOC is a 100% alternate build of LEGO Set 75399 Rebel U-Wing Starfighter, requiring no additional parts. Simply use the pieces from your 75399 set to assemble this compact and iconic Rebel ship. Key Features: Based on the classic Blue Squadron A-Wing starfighter Built entirely from 75399 — no extra bricks required Retractable landing gear for easy transition between flight and landing modes Cockpit space for one Rebel pilot minifigure Robust and sturdy design — ideal for both display and swooshable play Dimensions: Length: 20 cm (7.9") Width: 13 cm (5.1") Height: 8 cm (3.1") For Building Instructions and more Photos check out the Rebrickable Listing: LEGO MOC A-Wing (75399 Alternate Model) by codyaner.bricks | Rebrickable - Build with LEGO Quote
Feuer Zug Posted May 5 Posted May 5 Good work on building an A-Wing from the U-Wing set. Looks solid and has all the play features. Quote
baublitz Posted May 5 Posted May 5 Dang, you even have a little landing gear. Good work! How man pieces are left over? Quote
codyaner Posted May 6 Author Posted May 6 13 hours ago, baublitz said: Dang, you even have a little landing gear. Good work! How man pieces are left over? Thank you :) Roughly half of the pieces are left over. So you can still try to build something else out of the left-overs Quote
