Gunners TekZone Posted 11 hours ago Posted 11 hours ago (edited) @Bliss Yay, your wonderful efforts have succeeded in helping me make a dirt simple Blink routine for my Nano based Int-A simulator. Life is good! Edited 11 hours ago by Gunners TekZone Quote
evank Posted 10 hours ago Posted 10 hours ago 3 hours ago, Gunners TekZone said: Yes, you are correct. It was the input lines that I was thinking about, being directly wired to the connector. But they all are powered by the 5v line on same connector. I think this is an accurate resource of that, that someone else made. Still working on 1st coffee, so I could be hallucinating enough to rival AI Hey I recognize that image. :) Quote
Gunners TekZone Posted 8 hours ago Posted 8 hours ago (edited) 2 hours ago, evank said: Hey I recognize that image. :) Ha... I would be surprised if there was something Interface-A related that you didn't already have on file Oddly enough... I know found it somewhere else??? One of my many saved shortcuts... But I had a bazillion tabs open and lost track of where it was from. But at least now I have copies of all the rest of the matching schematics from your page I should have started on your page, but I often find it too hard for me to keep track of all the various website links, of the many technical things and projects I eventually want to reference from. Now I mosty save everything I want into dedicated file folders. Who knows, I might even get around to organising those a bit better... One day... Edited 8 hours ago by Gunners TekZone Quote
Bliss Posted 7 hours ago Author Posted 7 hours ago (edited) In the newest version, I added a While/Until condition in the Loop Forever block so it give more flexibility. Before the Loop Forever coud not exit... Also, you will notice at the right of the Connect RCX button, there is a CM check... Don't panic, I'm just preparing to tentatively add the CyberMaster support... Not finished yet... I'll let you know. I will add the support for the CM according to the information I got here and there but I do not own a CM... So I will count on testers to help on this... Edited 7 hours ago by Bliss Quote
