Rustinidiel Posted October 29, 2023 Posted October 29, 2023 Hi everyone! my doubt is about "hand" "arm" and "leg" parts: there is a way to connect the pin of the hand not on the arm hole? there is a way to connect the arm (the shoulder bubble or the hole inside the shoulder) not on the torso hole? there is a way to connect the single leg (i mean the hole for the hips) not to the hips? legal/illegal techniques suggestion are appreciated Quote
Trekkie99 Posted October 29, 2023 Posted October 29, 2023 My immediate thought for the hands is sticking them in pneumatic hose, and then inserting that assembly in a understud hole or maybe cramming it into a 318 clip. You might be able to stick hand pins in the leg pin hole. Will have to test. Arms, no idea lol. Search around for particularly greebly mocs like speeders for ideas. You see people use body parts on those models a lot lmao I can't believe I just wrote that XD Edit Actually I just remembered. YES you can insert hand pins into leg pin holes. I know because I did it in the past for a speeder moc lol. Quote
Rustinidiel Posted October 29, 2023 Author Posted October 29, 2023 (edited) 29 minutes ago, Trekkie99 said: My immediate thought for the hands is sticking them in pneumatic hose, and then inserting that assembly in a understud hole or maybe cramming it into a 318 clip. You might be able to stick hand pins in the leg pin hole. Will have to test. Arms, no idea lol. Search around for particularly greebly mocs like speeders for ideas. You see people use body parts on those models a lot lmao I can't believe I just wrote that XD Edit Actually I just remembered. YES you can insert hand pins into leg pin holes. I know because I did it in the past for a speeder moc lol. thanks for the suggestions... i'm trying to recreate the classic scene where a zombie wakes up from his tomb and a hand, or hand and arm, goes out from the ground... but the torso tilts the arm angle and it not fits to any "ground hole" Edited October 29, 2023 by Rustinidiel Quote
Rustinidiel Posted October 29, 2023 Author Posted October 29, 2023 I think I have found a simple and effective solution: Awakening by Rusty B., su Flickr Quote
