brick-builds Posted April 11, 2021 Posted April 11, 2021 Hello everywhere, I often see very pretty lego towns, but with less action. So I tried to design a truck in small size with powered up. What do you thing? It works, but is in an early stage: Quote
Toastie Posted April 11, 2021 Posted April 11, 2021 Well the problem in LEGO towns is: Automation. It is tough to negotiate the usually rather tight curves (baseplate based). Wide curves are not find that often. And this sort of limits the operation of remotely controlled cars/trucks. Your solution is nice though!!! Problem again may be the minimum radius you can steer your truck through, right? Best wishes, and thanks for sharing! Thorsten Quote
