Lira_Bricks Posted November 23, 2020 Posted November 23, 2020 Hello, I wanted to make a lego car with the following requirements: 6 studs wide Working doors Steering A working small steering wheel A size that allows a minifig sitting in the car to look through the window and to look a minifig standing outside in the eye at the same height Have the required lights for European roads Still look realistic (ignore the horn and wings ^^) Sadly I was not able to make it 6 studs wide. Below are a few assumptions I made. In case any are wrong please let me know. Minifig needs a seat of 2 by 2 There must be a steering axle with width 1 There must be an axle for the doors, which need a space of 1 1 + 2 + 1 + 2 + 1 is 7, so if any of the above can be made smaller, a width of 6 might be possible. I also want to make the car a bit shorter, but I don't see any place where that can easily be done Anyway, here is the car as it is now! And below is a size comparison. Both cars are equal in length, but the sportscar is higher. Small note: the two back doors should be white instead of grey and the reverse light should be transparent white instead of transparent blue Quote
