algiogia Posted May 5, 2020 Posted May 5, 2020 Is anyone aware on a way to use the servo to make multiple steps in a given direction? I.e. rotating it 2 times clockwise would move something 2 "steps" to the left. Then rotating 2 times counter-clockwise would bring it back to the center. Basically I need a mechanism that does nothing when the motor re-centers. Quote
Didumos69 Posted May 5, 2020 Posted May 5, 2020 (edited) https://rebrickable.com/mocs/MOC-22777/Didumos/motorized-90-shifter https://rebrickable.com/mocs/MOC-22027/Didumos/reliable-two-way-90-stepper/ Edited May 5, 2020 by Didumos69 Quote
brunojj1 Posted May 5, 2020 Posted May 5, 2020 (edited) Here another compact stepper with servo motor. Silicone band is not shown. Edited May 5, 2020 by brunojj1 Quote
algiogia Posted May 5, 2020 Author Posted May 5, 2020 Thank you Didumos69, very neat. However that only has 4 positions. I was looking into a linear movement, where I can go left or right indefinitely. P.S.: your models are amazing! Quote
Didumos69 Posted May 5, 2020 Posted May 5, 2020 2 hours ago, algiogia said: However that only has 4 positions. I was looking into a linear movement, where I can go left or right indefinitely. What is not indefinite about the movement in the examples I showed? They can move left endlessly and right endlessly. Or do you want something that is not confined to 90 degree steps? Quote
algiogia Posted May 5, 2020 Author Posted May 5, 2020 1 minute ago, Didumos69 said: What is not indefinite about the movement in the examples I showed? They can move left endlessly and right endlessly. Or do you want something that is not confined to 90 degree steps? Yes, sorry. I've just realized I could put a cog at the end to transfer the movement. Quote
Didumos69 Posted May 5, 2020 Posted May 5, 2020 Just now, algiogia said: Yes, sorry. I've just realized I could put a cog at the end to transfer the movement. Quote
algiogia Posted May 5, 2020 Author Posted May 5, 2020 2 hours ago, brunojj1 said: Here another compact stepper with servo motor. Silicone band is not shown. Thanks brunojj1. Where does the rubber band go? Quote
brunojj1 Posted May 5, 2020 Posted May 5, 2020 (edited) 3 hours ago, algiogia said: Thanks brunojj1. Where does the rubber band go? The silicone band goes around the orange 3L connector, attached to the yellow bushes. That makes sure the rotation stops at 90 degrees. EDIT: I´ve had a little mistake in my previous version and updated the links in the post. Edited May 5, 2020 by brunojj1 Quote
