Hello,
I'm building a UCS scale Impellor Fleet carrier which is one of my favorite capital ships in the Star Wars universe.
I want it to be stud-less and the final size will be 120x75cm.
Currently, I've only done the inner structure an there are already 2329 pieces, mostly technic with an astonishing number of 544x 2l pin.
 Impellor
My main goal is to build a big hangar (20x20cm) that will hold Tie fighters and a Lambda or a Zeta shuttle. I don't plan to do other interiors yet
Impellor_4
I hope you will enjoy and I'll keep you updated as much as possible.
  Reveal hidden contents
Flickr album
current stage :
impellor_7
100x75cm - 3263 parts
Edited by suruq
Small update: I'm currently working on the hangar structure but I have an issue with the wings.
Since I'm using stud.io my placement on cross axles isn't perfect.
it results in an offsetting of the plates on the wings.
To fix that issue I have 2 choices: fix the offsetting part by part (huge time loss) or buy the parts and start the build.
I'm not a big fan of the second option because of the financial aspect and also because I like to work on stud.io before the real build.
I don't know what to do yet :(
Edited by suruq
  On 1/31/2020 at 10:26 PM, m4st3rt3ch said:
Whatever you do, this looks promising. I can't remember any other MOC using this style of frame. Looking forward to it!
Expand
Thanks!
  On 1/31/2020 at 11:31 PM, AndrewShun said:
Any LEGO modeling is a time loss.
Expand
You're right in the case someone has thousands of pieces at his disposition but for a student like me, modeling is the only way to do LEGO mocs without spending money
  On 2/1/2020 at 1:44 AM, LiLmeFromDaFuture said:
Have you tried using the connect feature?
Expand
no, but I'll try. Perhaps it can save some time.
Expand
I think building it IRL is not only the right choice but also a necessity in case you want your model to be not just a virtual design concept with no real ambition of being a constructible model. Not only will the building in real bricks solve your alignment issues but (and more importantly) it will prevent you from ending up with a design which is totally infeasible due to lack of structural strength :)
Expand
yep, that what I'm going to do but it will take a very long time since I can't spend that much money right now (already 300$ according to BrinkLink).
I'll update you when I start the build.
hello,
I decided to fix the issue (4 boring hours) and here is an update :
impellor_7
the red parts on the wings are emplacements for canons.
I'm currently covering this with tile and the next step will be the wings bottom which is harder because of some hangar exit.
the build is 100x75cm and contain 3263 pieces
another update: I finished the top tiles
impellor_8
what do you think of the cannons?
(note: the little offset on the tiles is due to some bad angles and will not be there in the real build)
part count: 4350
  • 2 months later...
The wing assembly is looking pretty good so far, and I wish you luck on the task that is implementing the sheer amount of hangars this beast facilitates
  • 11 months later...
