mfair Posted November 12, 2019 Posted November 12, 2019 (edited) Hi, Is it straight forward enough to run two separate trains on a single layout using the Powered Up functions? Is this best (or only) achieved by having multiple controllers? I have purchased the 60197 Passenger set and the 60198 Cargo/Freight set plus quite a lot of extra track including six switches. Ideally I’d like to perform some shunting operations in a separate part of the layout simultaneous to running the passenger service on a wider arc of track. Thanks in advance for your help. Edited November 12, 2019 by mfair Quote
Roadmonkeytj Posted November 12, 2019 Posted November 12, 2019 In your scenerio yes. Run two separate hubs with the pass service on the controller and the shuntting using the app so you can customize speeds Quote
mfair Posted November 12, 2019 Author Posted November 12, 2019 9 minutes ago, Roadmonkeytj said: In your scenerio yes. Run two separate hubs with the pass service on the controller and the shuntting using the app so you can customize speeds Great thanks! Quote
Nivst Posted November 15, 2019 Posted November 15, 2019 I suggest you take a look at The Brick Automation project: Quote
mfair Posted November 15, 2019 Author Posted November 15, 2019 13 hours ago, Nivst said: I suggest you take a look at The Brick Automation project: Great thanks! Quote
