knotian Posted October 17, 2019 Posted October 17, 2019 I've searched but to no avail - could have missed it - for a simple transmission that does two things- 1-has one output that is continuously turning - and 2-one output at 90 degrees that can be reversed via a lever. Any suggestions wold be appreciated. Thanx Quote
suffocation Posted October 17, 2019 Posted October 17, 2019 You mean something like this? (red is input, yellow are the outputs) Quote
doug72 Posted October 17, 2019 Posted October 17, 2019 (edited) Or this This should meet your requirments. Red input and out constant direction Yellow output reversable with lever. Shock absorber for snap change over. Edited October 17, 2019 by Doug72 Quote
knotian Posted October 17, 2019 Author Posted October 17, 2019 Doug and suffocation Thanks, these will do the trick since after I posted I found out I need the 90 degree difference. Quote
