I bought a new electrician on bricklink.com (bb0961c01, bb0959c01, bb0960c01) and I can’t connect the hub to the lego control+.
The hub establishes only two connections (as I understand it) out of four, after which it disconnects.
Brickcontroller 2 establishes a connection with the hub, I can control the engines, but then only those that are connected to the C and D ports, and any engines in them work, even my old M-motors. The motors that are connected to ports A and B cannot be controlled; nothing happens when the sliders are moved.
Did anyone have this? Software problems or hub broken? Can I connect incorrectly?
Here is the unboxing video.
Must be connected to ports A,B,C at the same time. Other combinations are not supported, I hope that the restriction is temporary for a set 42099.
Thx a lot, every fine now.
BrickController2 version 1.7 has an unfortunate limitation that the motors connected to port A and B should be identical. It'll be fixed in version 1.8.
