eric trax Posted July 15, 2019 Posted July 15, 2019 (edited) Only one model today :D For a long time I wanted to build a classic agricultural trailer. It was supposed to be a standard double axle version. However, when I built the New Holland and Fendt tractors, I changed my mind and decided to build a tandem trailer. I made such a decision for a simple reason. The only output that can be controlled in tractors is the PTO shaft. This version of the trailer does not have to have a pneumatic system or engine to raise the kiper. In addition, the model had to be in a popular color because I wanted to create an instruction for it. The choice fell on Krampe Big Body 550. Trailer frame The frame is a fairly simple liftarm structure. The first version had a pendular suspension, but I had to remove it because the loaded trailer was unstable. Thanks to this, I could additionally strengthen the frame and move the cylinder towards the hitch in order to increase the load capacity. At the moment, it is about 1 kilogram Tipper I wanted to build a realistic model. Because of that I had to give up technic panels. If I used them, the tipper would weigh 1/3 of its current weight. Bricks are heavy, so the payload has dropped. The model looks very good like model–team one. I am glad that I managed to reproduce the curvature of the sides. The tailgate lifts automatically when the tipper is lifting. The trailer has a system of pull rods that lift it up. If the tractor has a pneumatic system, it can be replace by lego pnaumatic cylinders as a separate function Thanks for reading! Build instructions can be found here: https://rebrickable.com/mocs/MOC-26566/M_longer/krampe-550-tipper-trailer/ VIDEO: Edited July 15, 2019 by eric trax Quote
Maaboo the Witch Posted July 15, 2019 Posted July 15, 2019 Superb job! The balloon tyres are a great match for Trelleborg tyres. Quote
deraven Posted July 15, 2019 Posted July 15, 2019 Wow, that looks great! Excellent reproduction of the original, and properly functional, too. I'm a little surprised you didn't use 1x1 bricks for the bumper/crash bar to capture the shape given how perfect the rest of it is, but opting for more stability with the Technic parts makes sense. Quote
agrof Posted July 15, 2019 Posted July 15, 2019 Good enough. Just kidding, it is absolutely stunning, great extension to Your farming theme! Quote
trekman Posted July 15, 2019 Posted July 15, 2019 A very nice clean looking trailer. It certainly complements your range of tractors. Quote
ExeSandbox Posted July 16, 2019 Posted July 16, 2019 Wow, in the first image, I couldn't really tell that it was made out of LEGO bricks! A superb build! Quote
M_longer Posted September 16, 2019 Posted September 16, 2019 I have finally managed to add stickers and some green load to my copies of Eric Trax's New Holland TM140 tractor and Krampe trailer. More pictures:https://bricksafe.com/pages/M_longer/misc/nh140 Quote
Kio Liex Posted September 18, 2019 Posted September 18, 2019 This is sooo awesome. I really need to start saving for your models... Quote
