It has been quite a while since I posted a MOC on Eurobricks so here goes nothing! My current project is a C-model of the 42078 Mack Anthem. I am trying to make a telescopic handler with:
  • Telescopic two-stage boom
  • 4-wheel drive
  • 4-wheel steering
  • Detailed exterior
This is my progress so far (it looks very iffy at the moment, and I may scrap the chassis at some point but for now we will see):
Top view of the chassis (as you can see, four wheels are driven, four steered although the steering is not hooked up yet)
Sideways image showing steering angle :wacko:
Bottom view of chassis showing structural supports
Boom with axle connectors for chassis. (The middle U-joint is for support).
Side view of boom
This is a very ambitious project for my skill level, as my only prior experience with MOCs are nonfunctional ones. Hopefully this one turns out :sweet:.
* Also there is no reference that I could find on Google for a telehandler with 8 wheels, so this is not necessarily based off a specific model. *
Thanks for stopping by,
Magical Duck
Edited by Magical Duck
I don't think I've ever seen a telehandler with more than 4 wheels, but this does look more interesting than Lego's basic version (42061) from some years back.
Is there a reason why you went with 8 wheels?  Just trying to use a lot of the components since it's a C model?  If so, consider going with a detailed 4-wheel telehandler and maybe use some of the remaining part count to build a rack and some pallets (maybe with the rest of the wheels as cargo) for the machine to manipulate.
3 hours ago, Maaboo35 said:
Very odd choice of vehicle for an 8-wheel chassis. The turning circle on that thing would be massive. *huh*
Yes, so far the circle seems to be okay, if I can just hook it up together...
2 hours ago, M_longer said:
Telehandler. May I ask for reference picture?
See below:
The original idea was a four wheeled handler, but then the boom got too large. So I decided to pop four extra wheels on and call it a concept model :wink:. I may consider your idea, though. Thank you!
With parts only from 42078 you could built a telehandler, rack, pallets, and a truck which could transport those.
