  On 1/25/2019 at 7:56 PM, TeamThrifty said:
Never seen that before, and i like to think i'm pretty up on my tractors!! What is it?
edit.. schlüter Profi Trac!
Expand
You are correct, but with old style pistons V12 engine was bigger than half of tractor. In my country at that time MF with 2 cylinder engine was space shuttle :laugh: and when I saw this Trac on Austrian TV (ORF) I was shocked that something like this exist...and there was also MF 4800 articulated Trac which reminds me that we should stick to 1:12 MF 6716 tractor discussion and help @hpilto make his desired MOC or we will end up laughing whole evening...
Some WIP progress teasers
A complete redesign on the front end - initially due to a much improved pendular front axle unit, but then i found there was too much going on at the front (pendular turntable front support, steering gearing, drive to LAs for front linkage and drive to front pto) and not enough space to fit it all in, so i ended up with a slight tweak to the steering gearing layout and... quadlink suspended front axle! :grin:  - which a) solved those problems and b) has a certain 'oh yes' appeal to it. Happy days!
45966243745_22fb74fbca_z.jpgDSC_1152
39915906903_8fdc375d46_z.jpgDSC_1153
yellow 2L axle connector is the front linkage drive - with linear clutch, red 2l axle is the front pto drive, white 3l axle is the engine
45966239935_62db70b7bc_z.jpgDSC_1154
now working on the back end, so i can fit the wheel / axle mounts and diff, and then extend the frame forwards to meet the battery support frame...
39915904993_c1ca5ac531_z.jpgDSC_1155
still a bit to do... :look:
Hi, gentlemens. The best solution for the 2.2 tires is the 62mm D. x 46mm Technic Racing Large wheel from the Powe Puller set. Below is a photo for comparison. The solution is very stable and you can put a 10x10 dish on it
Edited by eric trax
