Weekends are favourable to building so I have some progress of cabin:
I have made the front from tiles and slopes because the technic panel is just too rough. It also allowed me to put there screen wipers and front hitch.
The second pair of racks finally arrived so I could test the whole setup of outridges, see them in action in video:
The problem is that the rear outridges are driven from front and the friction is quite high in whole system resulting in jerky movement. A second motor to power them would be better
Nice progress. Solution for pneumatics - may be adding an airtank 67c01 could help, and then adding valve after it. It might solve the problem with not simultaneous deployment.
As for 1 axle drive - do you think it will be enough to move it?
Edited by gate
Thank you. The air tank will not help, the delay is partly due to various length of tubbing and mainly due to different friction of cylinders, some are more than 20 years old. I have tested the drivetrain with 2kg of load and it driven fine, you can see it on previous page.
Just now, Sariel said:
The word is outriggers. Pardon me, but you keep using the wrong word.
Oops, thank you, I have to keep that in mind.
Never call anything "final", before you test it out throughly. So I had build boom in full length and glory - 6 wide, 7 high, 66 studs long, 4 section, almost direct copy of this boom from Nick Barrett:
15129160642_SPLASH.jpg from this crane: http://www.moc-pages.com/moc.php/443667
It looked like this:
44920885264_7d4aefab8c_c.jpgBoom 7x6 4-section
It works very smooth when short, reasonably smooth when 30 studs long, but impossible to extend when 66 studs long using PF motor ( VERY geared down). The problem is 3rd section made of smaller panels. It bows significantly because it is build from small parts next to each other. It is difficult to describe precisely, but the section is not flat, but curved. This creates a lot of friction when it slides in or out of the 2nd stage, because it have to bend to opposite direction. I have damaged several parts trying to extend the boom by string and finally decided to rebuild it. I would like to see how Nick's boom performed, I don't think that he was able to extend it using string only, without the help. Maybe I'm doing something wrong. I have to say that the fully extended boom looked more than impressive, total height was around 240 studs (~192 cm). So it was clear that I have to do something about that and obvious solution was to a) reduce section to 3, b) remove the section with most friction. I have left the first and second section as is, only reducing width by 1 stud as it wasn't needed. The 3rd section is left out and former 4th section is made bigger to fit into 3 brick high panel. I have also added pulleys to 2nd section end and front and to 1st stage front so the string can slide easily. Final boom is 5 studs wide, 7 high, 66 long, extends to ~180 studs (144 cm). Not as impressive as 4-stage, but still nice.
It looks like this:
45646136851_e27bdd6ff3_c.jpgBoom 5x7 - 3 stage
I also had to totally change lifting cylinder, the string operated one wasn't strong enough and string tend to "cut" into parts when it slides over them without support of pulley. It is nothing different that good old rack and worm gear, held together by some plates. Works like a charm. It is a little bit too wide compared to 5-wide boom, but that is lego..
31773739008_1187fca5be_c.jpg20181029_233900
You can also see some basic structure that will form superstructure, I have three L motors there - one for slewing - worm gear to 20t bewel and 12t bewel to turntable, other one for rising boom - 12t bewel to 20t, then worm on rack, last one for boom extension, with worm to 8t and second seto of worm to 8t. Ther will be 4th motor as well for winch.
Video of the boom is here, with some surprise at end:
Boom fully extended:
30704882617_ff94532454_c.jpgBoom 7x5 3-section
I would try a boom design where you have support at the rear end of a boom section. Lots of unnecessary friction otherwise. Not sure what the cross section looks like in your design though so maybe you already thought of that.
nice try!! it seems like 4 section booms have many problems to solve.
l also love the 4 section booms, especially extend with string.
How does it work? does it shrink when it nearly horizontal ?
  • 3 months later...
Soo after very long time I have finished it. I had to take a brake from it because of the lack of motivation. In the end most of the functions work, but not without stressing parts. I guess I had overexpectations about some key parts (boom, outriggers), but I have learned important lessons about crane building. Please excuse the pictures, my dslr failed just right before shooting and I'm left with phone only at the moment.
The final spec are:
Undercarrige:
L-motor for drive, 3rd axle is driven, connected to V6 engine
Servo motor for steering, alxes 1&5 and 2&4 have same steering angle, all axles feature ackerman geometry
M-motor for extending outriggers
M-motor for powering autovalve and pneumatic compressor, it is possible to lift the crane from ground, but not without parts stressing
Upperstructure:
L-motor for boom lifting
L-motor for slewing
L- motor for boom extension, extension through wire
M-motor for winch
Detachable counterweight
Whole album: https://www.flickr.com/photos/89695600@N07/albums/72157689610896333/with/46339523814/
46149695545_c8db5489cc_c.jpg20190210_160128
47011115772_0f751ec828_c.jpg20190210_160035
47011113762_7017da6b0b_c.jpg20190210_160605
47011113162_85bea7a03f_c.jpg20190210_160740
47063382341_a6039da50e_c.jpg20190210_161805
46339523814_ee371ace2f_c.jpg20190210_162320
Edited by Ivan_M
1 minute ago, mitx2529 said:
I like the boom , it's beautiful and funtional :thumbup:, can it retracted when it nearly horizontal
Yes it can retract in (almost) every position, it is operated by two strings winded in opposite direction. While the first one is winded in the second is released.
1 hour ago, Aleh said:
Looks complete and beautiful! Only bad fully extending boom is blending, so no heavy loads possible.
Thank you, yes it is not able to lift anything
1 hour ago, nerdsforprez said:
One of the cleaner cranes i have seen. Well done.
Thank you!
This is one cool crane.
This custom linear actuator is quite interesting. I wonder if you could provide some more detailed images?
Especially the mounting on the upper carriage interests me a lot.
It is already disassembled by you can see one picture of it here:
But of course it was already invented before, I got my inspiration from Dirk Klijn:
34042082022_7f5df668d5_c.jpgLiebherr LTM 1090 4.1 - Sarens by Dirk Klijn, on Flickr
What is different is the mounting, Dirks version ends with XL motor that rotate together with the accurator. In my version the accurator ends with
87408.png. It is attached to the centre of the turntable like this:
Thansk for share, i will try to modify my crane. :thumbup:
