4 hours ago, Tommy Styrvoky said:
I increased the spacing for the axle walls by 5 microns, I am going to keep the size for the original on Shapeways, as that is the dimensions that Efferman uses for his axles.
https://www.bricksafe.com/files/Tommy_styrvoky/replacement spindle for boost motor v2.stl
Champion. Thanks mate. I'll catch up with the maker group soon to get it printed and let you know how it fits.
On 1/7/2019 at 6:39 AM, rob79au said:
vxhall, thanks mate. What printer are you using? I'll check the specs as I want to make sure I use one with similar µm resolution.
Tommy, I have the original stl. Did you  get a chance to increase the axle size? If so, can I get a copy of this stl?
I use a local online printing service, don't know what kind of machine they are using. I think it's just some standard industrial printer.
Tommy,
Got a poor print from the local maker group using FDM. Local printing services want to charge me an arm and a leg.
Ordered 5 from your Shapeways store :). Have a number of these motors, so the spares won't go astray.
Thanks for all your help.
Rob
Tommy,
5 pieces arrived today and work a treat (have to boosts, so nice to know I have spares).
Thanks Tommy for the solution, and vxhall for raising the original forum post.
Rob
Hi Tommy!
I have the same problem with boost motor 6181852, the red part is broken. I tried to open the motor, but I was not succesful. Could you please explain me, how did you open that?
Thank you very much for your help!
Petr
23 hours ago, petrkubat1979 said:
Hi Tommy!
Petr
Petr, there are two tabs to push on the top and another two on the bottom (using screwdriver or similar).
Rob
On 2/17/2019 at 10:27 PM, petrkubat1979 said:
Hi Tommy!
Petr
Ahoj Petre,
chtel bych se zeptat, jestli se ti podarilo vytisknout tu hridel. Pokud jsi si to tisknul v nejaky firme, poslal by jsi mi prosim o jakou firmu se jednalo a na kolik to vyslo?
Predem diky
I did. I’ve had a replacement motor on back order for over a month.
Regardless, for the price of the replacement spindle I have a second/spare motor.
16 hours ago, Zbynek said:
Ahoj Petre,
Predem diky
Hello Zbynek,
 probably as a new member I can not write you directly. Please write me to my email: petrkubat1979(zavinac)gmail.com
