Update to the frame:
Here's a wheel mockup how it'd look with the wheel spacings. The gearing is 1:1.667
The frame is becoming a little bit more stiffer.. Axles and leafsprings finished. The suspension travel is not what i at first had in mind but the steering works so well that i can live with the stiff suspension.
It should be good in offroad terrain but not rock climbing. (Instead of making it even bigger, i'll just make a future project rock crawler instead.)
Here's the picture of the 90 degree gear angle in the middle:
If i grab the driven wheel by hand, the chassis will flex like a banana upwards and the driveshaft will break from the middle..
I assume after building the frame upwards, it'll get stiffer..
I wonder how much weight this thing can handle before gears starting to click.
I'm now thinking about attaching a winch in the front.. Probably will be manual though.. unless i make a clever gearbox in the middle and refit the motor somewhere else.
