nerdsforprez Posted May 23, 2018 Posted May 23, 2018 With Lego air tanks going on average, 34 dollars USD, here is a three-minute tutorial how to create your own. With virtually no end to the different shapes and sizes of medicine bottles, you can make an air tank fitting more.... or less (bigger or smaller) than the official Lego versions. Quote
BusterHaus Posted May 23, 2018 Posted May 23, 2018 Nice solution! Why not drill before sealing to make sure that there are no plastic chips inside? Quote
Aleh Posted May 23, 2018 Posted May 23, 2018 Wow! Just thank you very much for the idea!! I'll give a chance to make own airtank! Quote
sirslayer Posted May 23, 2018 Posted May 23, 2018 thank you @nerdsforprez !!! I agree that its cost for an Lego air tank is to much and that is a good idea and ill be using my girlfriend hemp pill bottle!! Quote
nerdsforprez Posted May 23, 2018 Author Posted May 23, 2018 10 hours ago, BusterHaus said: Nice solution! Why not drill before sealing to make sure that there are no plastic chips inside? Probably would have been a good idea. Though the plastic mostly curled around the drill bit as I drilled so really I don't think any got into the tank. Plastic was much more pliable than brittle. Quote
LucyCol Posted May 23, 2018 Posted May 23, 2018 13 hours ago, nerdsforprez said: With Lego air tanks going on average, 34 dollars USD, here is a three-minute tutorial how to create your own. With virtually no end to the different shapes and sizes of medicine bottles, you can make an air tank fitting more.... or less (bigger or smaller) than the official Lego versions Not so sure why you are paying so much for genuine Lego parts £6.96 on Bricks and Pieces here in the UK (Cheaper than BrickLink) Quote
Kingfisher Posted May 23, 2018 Posted May 23, 2018 This is a good alternative to using several Lego air tanks for storing a larger amount of air. I just wish the pumps did not have such low pressure relief valves so more energy could be stored in a smaller volume. Quote
