Henchmen4Hire Posted April 13, 2018 Posted April 13, 2018 (edited) Wanted to update my old build of the Steredenn ship so I twerked it into a more accurate shape. Also wanted to make some sections hollow to store weapons. Mainly posting this because I figured out a way to easily connect two halves, with the brick bottoms facing each other. I think this should be sturdy, just wish I had the pieces to try it out. The clips and bars are what hold the halves together. The bars let you squeeze the halves together without crumpling the hollow structure. Edited April 13, 2018 by Henchmen4Hire Quote
jakbar Posted April 13, 2018 Posted April 13, 2018 (edited) Interesting idea. I never thought of it before, but now it seems quite obvious. Might be very usefull in some situations. Good job! Edited April 13, 2018 by jakbar Quote
Henchmen4Hire Posted April 13, 2018 Author Posted April 13, 2018 (edited) That's how I feel every time I see other people come up with techniques, it seems so obvious once shown Some ideas for bracing larger builds, put those funky Technic pieces to good use Edited April 13, 2018 by Henchmen4Hire Quote
anothergol Posted April 14, 2018 Posted April 14, 2018 I've used this in some places, but if you have the room I'd also suggest this one on each side, its axle hole is full & very sturdy. Sturdy enough that you will only need 1 or 2 of them on each side. Quote
Henchmen4Hire Posted April 14, 2018 Author Posted April 14, 2018 (edited) 7 hours ago, anothergol said: I've used this in some places, but if you have the room I'd also suggest this one on each side, its axle hole is full & very sturdy. Sturdy enough that you will only need 1 or 2 of them on each side. Thanks for the tip! I switched to [2x2 round plate with axle holes] since I can place one high and one low. I think I might just need 1, all those other bars in there are also flush against the walls anyway. 10 hours ago, Bob De Quatre said: Why not use brackets? How would you incorporate them here? I'm used to building cars, I haven't figured out techniques I'm comfortable with (or that are even effective ) for spaceships yet. Edited April 14, 2018 by Henchmen4Hire Quote
Bob De Quatre Posted April 14, 2018 Posted April 14, 2018 12 minutes ago, Henchmen4Hire said: Thanks for the tip! I switched to [2x2 round plate with axle holes] since I can place one high and one low. How would you incorporate them here? I'm used to building cars, I haven't figured out techniques I'm comfortable with (or that are even effective ) for spaceships yet. test by BobDeQuatre, on Flickr Quote
Henchmen4Hire Posted April 14, 2018 Author Posted April 14, 2018 Neat, I'll see if I can make that work. The grill will probs be the biggest hurdle. Quote
Henchmen4Hire Posted April 14, 2018 Author Posted April 14, 2018 Tried the brackets, it works and is probably sturdier, but I like how easy the model is to split with these clips. I think I can actually switch to all axles, but I need to see if the clips and bars offer any significant rigidity. Quote
anothergol Posted April 15, 2018 Posted April 15, 2018 (edited) 8 hours ago, Henchmen4Hire said: Thanks for the tip! I switched to [2x2 round plate with axle holes] since I can place one high and one low. Round plates don't have a plate-thick axle hole, though, it's only at the end, so generally you need to stack 2. Trust me, 2 1x5 bars with just 1 axle should be way sturdier. Of course brackets will work as well, but keep in mind that brackets are rather poorly molded, I don't really trust them when it comes to getting perfect joints. Brick brackets can be trusted, though. Brackets with flat sides are nasty. 1x2 ones are even less precise than 2x2 ones. Brackets at the bottom & at the top will do fine, you will only see the gaps around the brackets themselves, not a problem when it's inside. Edited April 15, 2018 by anothergol Quote
swijak Posted April 19, 2018 Posted April 19, 2018 I agree, the 1x5 plate works best but I've got some shapes where I end up using 2x2 round plates backed by a 2x2 square to get it to fit better in a smaller space/different geometry. The only problem with this is that the axle pieces do no quite seat against the plates so the angles could be a little deformed with handling. I have found that once I everything is attached this is not much of an issue. Quote
