Hi everyone,
I want to share my version of 7755 with lights :classic:
The locomotive is lower than the original using a strip of plate instead of gray bricks to promote the right height compared to others locomotives and 12 volt wagons
The power supply circuit takes current from the motor, the current is rectified with a diode bridge and two resistors protect the leds to make them work at the correct voltage
Lights off...
...and lights on! :wink:
Enjoy the pictures and vides :sweet:
Edited by LEGO Train 12 Volts
Nice work! I definitely prefer your lower version. How do the lights look in the dark, or when the loco is running on it's own? How effective are the LEDs at actually lighting the track ahead?
7 hours ago, Paperinik77pk said:
Pics are so clean anddefined...and let me say the pallets under the boxes are a very fine touch!!! :thumbup::thumbup::thumbup:
Thanks Paperink, for the pictures I've change my last mobile with a new S7, about the pallet the color is from 2000 but pretty good also for the 80's :wink:
7 hours ago, Carrera124 said:
The lowering using grey plates instead of bricks really makes it fit better to all other 12v trains.
I agree, the grey strip is the best compromise! :thumbup:
The led illuminate better than the light brick, but the prism reduce the capacity to illuminate the path :classic:
Hi Emanuele,
very nice work! I always admire your soldering skills. The light is really very bright - I guess I have to copy your approach if you don't mind.
All the best!
Thorsten
11 hours ago, Toastie said:
The light is really very bright - I guess I have to copy your approach if you don't mind.Thorsten
You're always welcome Thorsten ...just a hint for you: with a capacitor the circuit is better than now and the light more stable :classic:
  • 2 months later...
