9v system Posted January 28, 2018 Posted January 28, 2018 hi all i have a XL motor from the volvo loader set which i used in the invisible lift gbc but after using it, the motor only runs in one direction now and needs a push to get it going? is there anything i can do? Quote
Alex Ilea Posted January 28, 2018 Posted January 28, 2018 Contact Lego to send you another one, they have an amaizing customer service! Quote
mocbuild101 Posted January 28, 2018 Posted January 28, 2018 Does it make any noise when trying to go in the other direction? If so, it's most likely that one of the gears inside it is damaged. Quote
9v system Posted January 28, 2018 Author Posted January 28, 2018 2 minutes ago, mocbuild101 said: Does it make any noise when trying to go in the other direction? If so, it's most likely that one of the gears inside it is damaged. no it doesnt it turns fine by hand and all the gearing is ok its a problem with the motor itself Quote
RohanBeckett Posted January 28, 2018 Posted January 28, 2018 (edited) Phone Lego.. tell them what's wrong, and what set it came in.. they will send you a new one I've done it for a M motor before... took less than 5 mins on the phone, and new motor arrived within 2 weeks Edited January 28, 2018 by RohanBeckett Quote
dannydos Posted January 28, 2018 Posted January 28, 2018 Try pulling the contacts out a little bit on the motor cable. Sometimes, but not all the time it's just a bad connection at the receiver. Quote
mocbuild101 Posted January 29, 2018 Posted January 29, 2018 20 hours ago, 9v system said: no it doesnt it turns fine by hand Hmm... Strange, I have no idea what would cause that... Quote
