Boernie Posted September 25, 2017 Posted September 25, 2017 Hello everyone,I have a little problem in the program Stud.io. The technic stone (Technic Flex Cable End Double, Pin Connection) can not connect to the (3673 Technic, Pin without Friction Ridges Lengthwise). What am I doing wrong? He can not be pushed on and always jump aside and if, then not completely up to the stop. Quote
KamalMYafi Posted September 28, 2017 Posted September 28, 2017 (edited) I think that the Stud.io recognize it as an illegal connection. If you really want to connect that, you might want to turn off the collision detection and place it to the middle of it. As you can see that the part is not perfectly aligned, to fix that, you should move the part with the "fine grid" control until you feel it right to it's place... Edited September 28, 2017 by KamalMYafi Quote
