I would just use the cockpit design from the official First Order Tie Fighter, and mod it, since that is the most round (as in a ball) cockpit we currently have.
3 hours ago, Rustinidiel said:
hi, i'm trying to do a Tie_Defender moc.. and i ask to you if someone got a suggest or make the round cockpit
You can use any Tie Fighter model design out there. Just skip the wings part from both sides and you're ok :)
the problem is to make the cockpit really spherical.
cutting out the wings structure let the design not spherical...
What you could do is take the official tie striker, and modify the fuselage part to make it a lot shorter, then change the wing connection and configuration. That should get the round eyeball shape, and have a way to attach the wings.
