Hi guys! Today I'm happy to show you my lastest moc. As you can see by the title it is a mack granite truck and for more precision a GU813! This one:
Personnaly I think that these truck are one of the most beautiful trucks!
And here is my lego version:
DSCN3642
It is powered by two xl motors (6x4) ,one servo and two pairs of pf lights
It's not finished yet, but it will be ready soon! The top and the back of the cab are always one of the most difficult part in the build (I think). I use the same color as my Caterpillar but this time all the truck is black, and with red and white stripes
At this point I'm very proud of how it turns out. And just for you to know, I've starded this two days ago (the hood,bumper and cab) the chassis was already built for an other truck but this one took is place you can see the blueprint of a scania LT146 under it!
Some more pictures:
DSCN3643DSCN3644DSCN3645DSCN3646DSCN3647DSCN3648DSCN3649DSCN3650DSCN3655
Thanks for reading! Hope you like it.
Don't hesitate to post if you have any question or remark! There will be more updates this week and maybe it will be finished!
But the truck on the first photo is a five axle dumptruck, is yours going to be a five axle truck or is it going to stay a three axle truck?
12 hours ago, Technivor said:
Thanks! For the suspension it is 2legoornot2lego's mack granite and scania system!
For me it looks like a mix of few Ingmar's trucks. Both chassis and cab.
Edited by M_longer
2 hours ago, jono rocky said:
Brilliant so far just one thought have you considered adding the other two steerable lift axles t make it more unique? But still it is really going good.
Thanks but it will stay a three axles truck. The picture was just to show you the cab and Hood of truck! I had already made one with two steerable axles for my Caterpillar so I don't want to try for now!
What do you mean by mix only the axles or the entire truck?
I do not see exactly what you have put inside the frame, but at first look it looks like mix of these two:
Hope you are wrong and truck is being build uniquie, maybe just inspired by Ingmar's great projects!
The other way coping is not bad if you tell the truth about it.
My 2 cents... I would agree with M_longer and Edwin Korstanje.  At first look many details in both body and frame mimic exactly those found in Ingmar's truck.  I think it's ok to build your own concept based on seeing images of an existing lego MOC but would be appropriate to cite such inspiration as well.
I know that it look like a mix of these two trucks and I assume that I have taken some inspiration from some parts but its not very strange that they look similar when the real truck looks like a mix of these too! For the frame, the rear axles will probably be just there for now because I try to modify my Caterpillar's axle setup because it was only made for AWD, when the front driven axle was removed the gears had problem (cracking gears)!
Edited by Technivor
My 2 cents, good for Technivor if he is able to reverse engineer Ingmar's trucks.  If he builds the truck exactly piece by piece, then takes it apart and changes it to make it his truck, I think that is awesome.
Even if he "copys" the truck, so what? How many other people completely copy someone else's build (with or without instructions) because they love it so much.
Technivor, your truck is looking great, I look forward to seeing the progress.  Keep up the great work!!! :)
Thanks! I've never built any of his trucks but I would like to. When I want to know how a moc is built or its mechanic I normally take pictures of it even if they are not so good. This is how I have found how to make Ingmar's chassis:sweet: but if I could buy is instructions I would do it without hesitation for is mack vision but for now I can't.:cry_sad:
3 hours ago, M_longer said:
Sorry, but for me it looks like Ingmar's truck in different colour scheme.
Honestly, so what.  :classic:
I'm being blunt, because you have made the same comment multiple times.   Technivor answered your question politely, even though it could be seen as hostile by some.
There's only so many ways to skin a lego cat.  You're not paying any entry fee here.  It's not a contest entry, and he's not selling instructions.
It's a great truck. :wink:
Edited by andythenorth
I think it's a great truck too. How many models look like other models? Probably most of them.....
I wish I could do that kind of work with system bricks. Well done. :thumbup:
It is a great truck, I couldn't build this from scratch, but it does look a whole lot like Ingmars trucks.
And I agree also, he is a great inspiration source.
