uefchen Posted January 21, 2017 Posted January 21, 2017 Cutting Machine I wanted to make it quite spectacular. Cut off a roll, and then run a TPC machine. The goal was something very high. The result is a cutting machine. Have fun while looking, greeting https://www.youtube.com/watch?v=SOXFdumUuWg&feature=youtu.be Quote
roppie11 Posted January 21, 2017 Posted January 21, 2017 what a pity it failed. If it worked it would be a pretty cool machine! Quote
Burko-uk Posted January 21, 2017 Posted January 21, 2017 Try with something less dense (in a loose sense). There's a lot of "Stuff" that you are trying to cut, and all the material will drag on the blade and cause friction, which is where it failed. Maybe try with just the centre card tube? Quote
