weldingdragon Posted June 29, 2016 Posted June 29, 2016 (edited) hello can any one help me with this file all i want to do is build this custom model i just need the the instructions but i dont know ment=17681how to used ldraw can someone make this file into pdf file any help would be great thanks Delorean-BTTF.ldrFetching info... Edited June 29, 2016 by weldingdragon Quote
Capn Frank Posted June 29, 2016 Posted June 29, 2016 On 6/29/2016 at 3:26 PM, weldingdragon said: hello can any one help me with this file all i want to do is build this custom model i just need the the instructions but i dont know ment=17681how to used ldraw can someone make this file into pdf file any help would be great thanks Moved this topic related to LDD issues to the LDD Forum, and removed your three duplicate topics. Why did you make 4 duplicate topics? Quote
M_longer Posted June 29, 2016 Posted June 29, 2016 (edited) On 6/29/2016 at 4:46 PM, Phred said: Moved this topic related to LDD issues to the LDD Forum, and removed your three duplicate topics. Why did you make 4 duplicate topics? Because it helps in getting attention, you did not know that? Just open those files with Lpub and you will be able to build it. You can just click on the PDF generator icon, but If you will read about using that program, you will be able to generate instructions with steps. With my settings it looks like this: Edited June 29, 2016 by M_longer Quote
Capn Frank Posted June 29, 2016 Posted June 29, 2016 On 6/29/2016 at 8:18 PM, M_longer said: Because it helps in getting attention, you did not know that? There should only be one topic for one discussion. Otherwise there will be parallel discussions, and the board could be filled with unnecessary, duplicate topics in the same forum or multiple forums. Each forum has so much space in the first page and should not be filled with duplicates. Deliberately creating multiple topics about the same thing is frowned upon. Quote
KamalMYafi Posted June 29, 2016 Posted June 29, 2016 Anyway, if you convert LDraw to LDD via LDD import, it will make many parts removed from the model. Quote
weldingdragon Posted June 30, 2016 Author Posted June 30, 2016 do u think you can sand me the pdf file please thanks Quote
M_longer Posted June 30, 2016 Posted June 30, 2016 On 6/30/2016 at 12:39 AM, weldingdragon said: do u think you can sand me the pdf file please thanks No, I have other things to do in Lpub. Quote
