hi,
I have bought 42043 mercedes arocs set.
I request an advice from you for make this set motorized function.
so, which parts I must buy for make this set motorized?(gears-axles..etc)
is this set enough?
http://www.ebay.com/itm/Lego-Power-Functions-SET-4-S-technic-motor-receiver-remote-speed-joint-gear/252382840375?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211132617%26meid%3D7bf43c221956485cbf91274e9bd2bbc7%26pid%3D100085%26rk%3D2%26rkt%3D4%26sd%3D272247135026%26clkid%3D5776342517027354973&_qi=RTM2247626
thank you for your interest.
best regards.
I agree saberwing, though I would use an Xl motor attached directly to the drivetrain. It has enough speed, and one l motor drive is not enough to go through both differentials and the straight six and to still be playable.
Edited by Myers Lego Technic
You'd be better off ordering the parts from Lego, rather than buying on ebay. Also, do you want to motorize every function, or just the drive and steering? Unless you have a lot of parts to experiment with, it is really difficult to say what you need. You might want to check out the Mods and Improvements thread.
thank you.
i want use it for drive an steering only.offcourse, its must have IR and remote.
I recommend to watch the following videos. Among them you will find all the necessary parts and instructions.
For A-model:
For B-model:
I have build both models with those instructions.
For A-model:
For B-model:
