Hod Carrier Posted February 8, 2016 Posted February 8, 2016 Hello, Silly question, perhaps. I can't find the PF L Motor on LDD. The M and XL Motors are there together with one or two others, but no L Motor. What have I missed? Quote
JJ2 Posted February 9, 2016 Posted February 9, 2016 The L-motor does not exist in LDD or the servo motor Quote
Hod Carrier Posted February 9, 2016 Author Posted February 9, 2016 Thanks for the reply. I thought it was the case but I wondered if it was hiding on some other menu I'd not discovered yet. Is there somewhere to report and request missing parts be added? Alternatively, does anyone have a brick-built dummy motor to use in LDD that they would be prepared to share? Many thanks. Quote
Calabar Posted February 9, 2016 Posted February 9, 2016 (edited) Alternatively, does anyone have a brick-built dummy motor to use in LDD that they would be prepared to share? Try listing all the sets that use this Motor and look for them inside the LDD Official Sets topic, maybe you can find some brick build solution there. PS: request for parts have to be made here, where your topic will be moved later! Edited February 9, 2016 by Calabar Quote
Hod Carrier Posted February 9, 2016 Author Posted February 9, 2016 Try listing all the sets that use this Motor and look for them inside the LDD Official Sets topic, maybe you can find some brick build solution there. Forgive me. This is not a personal attack, but... I'm not unpicking a 4x4 Rock Crawler (for example) in an attempt to find an LDD template for the L Motor when I have no idea where in the model I'm meant to be looking for it, what it looks like and which of the almost 1300 parts have been used to create it. Isn't life already adequately short...? Wouldn't it be simpler to have a thread where people can share templates for components not currently supported in LDD? It wouldn't need to be a long thread and would be a lot easier and friendlier to use. Quote
Stephan Posted February 9, 2016 Posted February 9, 2016 Check this post: http://www.eurobricks.com/forum/index.php?showtopic=42465&st=50#entry1582677 Quote
Hod Carrier Posted February 9, 2016 Author Posted February 9, 2016 Thank you. Much appreciated. :-) Quote
Calabar Posted February 9, 2016 Posted February 9, 2016 (edited) I'm not unpicking a 4x4 Rock Crawler (for example) in an attempt to find an LDD template for the L Motor when I have no idea where in the model I'm meant to be looking for it, what it looks like and which of the almost 1300 parts have been used to create it. Isn't life already adequately short...? I did this operation many times, it is not difficult nor too long. Are you sure you have understood what I suggested to do? Wouldn't it be simpler to have a thread where people can share templates for components not currently supported in LDD? It wouldn't need to be a long thread and would be a lot easier and friendlier to use. Stephan anticipated me. The topic is the one he linked above. Unfortunately it is not much used and it is not adequately indexed, so find a part there is not so trivial (luckily it is not too long). Edited February 9, 2016 by Calabar Quote
