Pego Posted January 17, 2016 Posted January 17, 2016 I am currently building a small 4wd rally car, but was wondering if it is ok to expose a little bit of the buggy motor to snow (up to the marked point). I know the electronics are up high, but there might be some grease or metal parts in there that could be damaged by the water. Buggy motor question by Pego's Legos, on Flickr Quote
tibivi Posted January 17, 2016 Posted January 17, 2016 yes, it is possible, i had a couple of rc buggy motors on a boat with the bottom in the water and they are fine. They even went some time under water when the boat sank. :) I also used them in the snow ad they had no problem with it. Quote
dr_spock Posted January 17, 2016 Posted January 17, 2016 Fresh clean snow may be fine. I would avoid road salted snow or slush. Quote
Pego Posted January 17, 2016 Author Posted January 17, 2016 Ok, thanks for the replies, I 'm going to try it then Quote
Beck Posted January 17, 2016 Posted January 17, 2016 Lego motors are suprising resilient to the elements. I've gotten an IR receiver drenched in rainwater causing it to short out, but after a few hours of drying it was in working order. A few years ago I made an RC boat that capsized sending all of the pf elements into the water. After a few hours of drying, can you guess what happened? .... Yes, they were in working order. In conclusion, I wouldn't be even the slightest bit worried about snow. Quote
BusterHaus Posted January 17, 2016 Posted January 17, 2016 If you can, try to cool down the model below the freezing point before bringing it outside. This will prevent the model from melting the snow and water getting on the parts. It will also make the model less likely to have snow stuck to it. Quote
geezerman402 Posted January 17, 2016 Posted January 17, 2016 Certainly in the short term it will be fine, but long term the motor might seize up or get weak. Quote
