You mean 3D model for LDRaw? These all are available - search for part numbers: 44225, 44224, 48171 and 47455.
Technic Pin with Friction with Click Rotation Pin (47455)
Is there a part that connects to this ?
Found it:- Technic Pin with Friction with Click Rotation Ring (41680)
Edited by Doug72
48171 is intended to work with 47455. It could be there are more compatible parts working with 47455. For 41680 two 41679 are needed. 41681 is needed for both 47455 and 41680 for longer side (or left side pin on the picture above). Obviously you can use beams and connectors as well as these are simple pins.
  On 1/16/2016 at 9:57 AM, Nevercallmebyneme said:
serious? it's that easy?
Quick result in LDCad:
Edited by zux
  On 1/16/2016 at 4:56 PM, Nevercallmebyneme said:
can these files be opened in say, 3DSMax for modification?
You can use LDview to export an LDraw file to an .stl or .3ds file.
Although, I don't know how good the export quality is.
Alternatively, there's also a LDraw importer for Blender (google it). You can import the LDraw file into blender and then use blender to export it to a variety of other formats.
Again, there might be quality loss. I have no idea.
