As for me it was clear that there is a risk to overwright lg_defs.
Anyway, I will try to update everything not to have those compatibility issues asap.
If you can provide the part numbers that gives you an error, it would help.
For starters, you can grep all the parts for the variable LG_INNER_CORNER_SPACE, none of which currently work.
Also, your "lg_defs.inc" is missing the objects "lg_tech_knob_join", "lg_tech_knob_join_clear" and maybe others. Any parts that use them also don't work currently.
Lastly, if you are still using Lutz's old "lg_color.inc" file, none of those colors are compatible with POV-Ray 3.7's SRGB system. Owen's file *is* compatible, however.
Edited by Dilvish
Update: 2017/04/05
Download link on first page.
2572: Panel 6 x 6 x 9 with Curved Top
2578b: Brush Holder Street Sweeper with Hinge Bottom
3069bp01: Tile 1 x 2 with Letter Pattern
3935: Wing 4 x 4 Right
3936: Wing 4 x 4 Left
4162p11: Tile 1 x 8 with "Berlin" Pattern
4162p12: Tile 1 x 8 with "New York City" Pattern
4162p13: Tile 1 x 8 with "United States Capitol Building" Pattern
4162p14: Tile 1 x 8 with "Buckingham Palace" Pattern
4865bp01: Panel 1 x 2 x 1 with Rounded Corners with Brick Wall and Tunnel Pattern
4865bp02: Panel 1 x 2 x 1 with Rounded Corners with Light Blue Sky and Grey Skyline Pattern
4865bp03: Panel 1 x 2 x 1 with Rounded Corners with Light Blue and Green Arrows on Tan Background Pattern
6027: Animal Dragon Head
6028: Animal Dragon Tail
6141: Plate 1 x 1 Round
6184: Arch 1 x 12 x 5 with Curved Top
18674: Plate 2 x 2 Round with 1 Centre Stud
21229: Fence Spindled 4 x 4 x 2 Quarter Round with 3 Studs
30044: Window 1 x 2 x 2.667 with Rounded Top
30046: Window 1 x 2 x 2.667 Pane Lattice Diamond with Rounded Top
30056: Fence Spindled 4 x 4 x 2 Quarter Round with 2 Studs
30167: Minifig Hat Wide Brim Flat
43719: Wing 4 x 4 with 2 x 2 Cutout
51011: Tyre 6.4/75 x 8 Shallow Offset Tread
51739: Wing 2 x 4
60849: Minifig Hose Nozzle with Side String Hole Simplified
86500: Dome 4 x 4 Smooth
87617: Cylinder 1 x 1 x 4.333 with Handle
88293: Brick 3 x 3 x 2 Round Corner with Dome To
92947: Brick 2 x 2 Round with Grille
99780: Bracket 1 x 2 - 1 x 2 Up
99781: Bracket 1 x 2 - 1 x 2 Down
Edited by Darats
  • 4 weeks later...
On 29-4-2017 at 6:01 AM, SpaceMan Nathan said:
Hey, I just reinstalled on a new computer.  I am looking for Owen's color file, but his dropbox where he had the file is down.  Do you have his color file?
I believe I have his files on my PC. I also have this .zip file on my Onedrive, but I'm not 100% sure if the color file you're looking for is in there.
Otherwise, I have it on my desktop at home, but I'm not home this weekend so in that case you'll have to wait :wink:
Thank you, I will give it a look over.
Update: 2017/09/03
2431pz0: Tile 1 x 4 with Black Utility Belt Pattern
2431pz1: Tile 1 x 4 with Black and Light Yellow Triangle on Red Rectangle Pattern
2599: Minifig Flipper
3003p0b: Tile 1 x 8 with Gold and White Big Ben Clock Face Pattern
3004pz0: Brick 1 x 4 with Bright Green Tie with Bright Light Orange Skulls Pattern
3010pz0: Brick 1 x 4 with Batman Logo in Yellow Oval Pattern
3010pz1: Brick 1 x 4 with Yellow Batgirl Logo with Black Border Pattern
3010pz2: Brick 1 x 4 with Yellow Colar and Yellow Robin Logo Pattern
3010pz3: Brick 1 x 4 with Black Line, Light Orange Skull and Magenta Pockets Pattern
4162p15: Tile 1 x 8 with "THE SOLOMON R GUGGENHEIM" Pattern
4162p16: Tile 1 x 8 with "Sydney" Pattern
4162p17: Tile 1 x 8 with "Chicago" Pattern
4162p19: Tile 1 x 8 with "London" Pattern
11090: Bar Tube with Clip
11208: Wheel Rim 10 x 14 with Fake Bolts and 6 Spokes
11458: Plate 1 x 2 with Offset Peghole
11476: Plate 1 x 2 with Clip Horizontal on Side (Thick C-Clip)
11477: Slope Brick Curved 2 x 1
15068p05: Slope Brick Curved 2 x 2 x 0.667 with "MUSEUM" Text Pattern
15070: Plate 1 x 1 with Tooth Perpandicular
15208: Plate 1 x 2 with 3 Teeth In-Line
15209: Tile 1 x 2 with 2 Teeth Vertical
15395: Dome 2 x 2 Inverted with Stud and Tube
15397: Plate 3 x 3 Cross
15571: Slope Brick 45 1 x 2 Triple with Bottom Stud Holder
18649: Plate 1 x 2 with Handles on Opposite Ends
18654: Technic Beam 1
18677: Plate 1 x 2 with Offset Peghole on Underside
18976: Wheel Rim 11 x 18 with Vented Disc Brake
22385: Tile 3 x 2 with Angled End
22388: Slope Brick 50 1 x 1 x 0.667 Quadruple
22885: Brick 1 x 2 x 1.667 with Studs on 1 Side
23443: Bar Tube with Handle
23950: Panel 1 x 3 x 1 with Rounded Corners
24246: Tile 1 x 1 with Rounded En
24299: Wing 2 x 2 Left
24307: Wing 2 x 2 Right
24309: Slope Brick Curved 3 x 2
25269: Tile 1 x 1 Corner Round
25866c02: Figure Friends Lipstick with White Handle
26603: Tile 2 x 3
26604: Brick 1 x 1 with Studs on Two Adjacent Sides
30340: Minifig Life Ring
32294: Technic Suspension Arm 1 x 9 x 2.5
45677: Wedge 4 x 4 x 0.667 Curved
48729b: Bar 1.5L with Clip with Truncated Sides and Hole in Shaft
50745: Car Mudguard 4 x 2.5 x 2
50950: Slope Brick Curved 3 x 1
50990a: Dish 10 x 10 Inverted with Hollow Studs
50990b: Dish 10 x 10 Inverted with Solid Studs
55707c: Minifig Batarang
61409: Slope Brick 18 2 x 1 x 2/3 Grille
61678: Slope Brick Curved 4 x 1
64727: Bar 0.5L with Blade 3L
86208: Minifig Torch without Grooves
87079pz0: Tile 2 x 4 with Groove with Brickheadz Series Number "1"
93606: Slope Brick Curved 4 x 2
95108: Friends Lipstick Handle
95109: Friends Lipstick Core
98138: Tile 1 x 1 Round with Groove
98138p07: Tile 1 x 1 Round with Eye Pattern
98138pz0: Tile 1 x 1 Round with Two White Squares Pattern
99774: Minifig Ski 4L without Hinge
  • 4 weeks later...
Here I am I believe correctly ;-) Good job!
I have problems with connectors 1 - 6
In your package the connector 1 (32013) is reworked by you - this is now perfect.
Do you still make the others please? I would like to do it myself, but I do not know how ...
Hi, just give me part numbers you want, and I will model them for next update.
Also, could you explain what problem you have with the existing ones ?
  • 4 months later...
Update: 2018/02/05
11209: Tyre 10/32 x 14
11291: Wedge 3 x 4 x 0.666 Cutout
18977: Tyre 11.2/28 x 17.6 Intermediate
2431pz2: Tile 1 x 4 with Black Lines and Medium Azure and White Half Circle Pattern
2431pz3: Tile 1 x 4 with Black Moustache Pattern
25214: Cylinder 2 x 2 Elbow with Axle Holes
2530: Minifig Sword Cutlass
30028: Tyre 8/40 x 8 Slick Smooth
30031: 30031: Minifig Handlebars
3004pz1: Brick 1 x 2 with Collar and Tan Skin Pattern
3010pz4: Brick 1 x 4 with 3 Dark Red Vertical Stripes Pattern
3010pz5: Brick 1 x 4 with Silver Star and 2 Belt Buckles Pattern
3010pz6: Brick 1 x 4 with Black Pectoral Muscles Pattern
3010pz7: Brick 1 x 4 with Black Abdominal Muscles Pattern
3069bpz0: Tile 1 x 2 with Black Lines and Medium Azure and White Circles Pattern
3069bpz1: Tile 1 x 2 with Silver Rectangles and Medium Azure Trapezoid Pattern
3069bpz2: Tile 1 x 2 with 3 Dark Red Waves Pattern
3070bp00: Tile 1 x 1 with White Top Square Pattern
3176: Plate 3 x 2 with Hole
32014: Technic Angle Connector #6 (90 degree)
32015: Technic Angle Connector #5 (112.5 degree)
32016: Technic Angle Connector #3 (157.5 degree)
32034: Technic Angle Connector #2 (180 degree)
32192: Technic Angle Connector #4 (135 degree)
3245a: Brick 1 x 2 x 2
3245b: Brick 1 x 2 x 2 with Inside Axleholder
3245c: Brick 1 x 2 x 2 without Understud
3245cpz0: Brick 1 x 2 x 2 without Understud with Black, Silver and Red Jacket Pattern
3299: Slope Brick 33 2 x 4 Double
3622pz0: Brick 1 x 3 with Dark Red Lines, Brown Belt and Dark Nougat Buckle Pattern
3749: Technic Axle Pin
40379: Animal Tail Section End
4083: Bar 1 x 4 x 2 with Studs
42446: Bracket 1 x 1 - 1 x 1
43720: Wedge 4 x 2 Sloped Right
43721: Wedge 4 x 2 Sloped Left
43857: Technic Beam 2
50946: Car Grille 2 x 2.5 x 3 with Sloped Front
6005: Arch 1 x 3 x 2 with Curved Top
62360: Windscreen 3 x 6 x 1 Curved
6536: Technic Cross Block 1 x 2 (Axle/Pin)
6562: Technic Axle Pin
75902: Minifig Shield Round Bowed
75902p02: Minifig Shield Round Bowed with Bullseye with Star Pattern
87079pz1: Tile 2 x 4 with Groove with White "A" and 4 Black Lines Pattern
88930: Slope Brick Curved 2 x 4 with Underside Studs
88930pz0: Slope Brick Curved 2 x 4 with Black Line and Dark Red Rectangle Pattern
  • 2 months later...
This is great. Thanks for sharing.
While checking I've noticed something strange: all the Technical Axle Flexibles are working for me except 32580. It lg_32580.inc does not exist.
I don't see what's wrong here. My old LGEO.xml in LDView's folder might be outdated? It's defined there, though, but none of the working ones
Edited by debriel
8 hours ago, STRFY said:
need better instructions how how to use this
What don’t you understand? I can help.
Hi, I've recently re-installed LDraw (using AIOI) on my new computer, and just want to double check what I need to do to use your LGEO parts (as I have forgotten what I did last time... :sceptic:)
By what I understand, all I need to do is copy the parts and the xml file to they're default directories, overwriting anything that's already there... or have I missed something?
Yes, you have to copy the parts and the xml file where they should be, and overwrite when prompt.
Be aware that if you overwrite the lg_defs.inc file of the AIOI by mine, you might get some trouble with some parts. To avoid this, you’de better edit your existing lg_defs files and add the two statements written on the very first post of this topic.
I’m still working to integrate this package to the AIOI to avoid all this unfriendly steps.
Let me know if you get some trouble.
Great, thanks, I will make sure to backup the lg_defs.inc file if I use yours.
Will do, but hopefully I won't need to...
  • 10 months later...
When rendering technic liftarms with POV ray, I think there is a bug in LGEO. The axle holes are only visible in the half of the part:
Does anyone see the same problem? - Or have an idea how to fix this?
I think those parts comes from the original LGEO library. They have not been made by me.
It is not impossible that some issues exists. You need manually correct the parts or wait until someone correct them.
  • 3 months later...
Update: 2019/07/03 - 1
572a: String End Stud
572c: String Minifig Grip
2431pzb: Tile 1 x 4 with Black Stormtrooper Utility Belt Pattern
2431pz6: Tile 1 x 4 with Dark Red Lines and White and Yellow Circle Pattern
2431pz7: Tile 1 x 4 with Black Moustache and Black Beard Pattern
2431pz8: Tile 1 x 4 with Black Outlined White Teeth Pattern
2431pza: Tile 1 x 4 with Dark Red Rectangle and 2 Dark Red Trapezoids Pattern
2431pzc: Tile 1 x 4 with Metallic Silver Stormtrooper Utility Belt Pattern
2453a: Plate 1 x 1 x 5 with Hollw Stud
2453b: Plate 1 x 1 x 5 with Solid Stud
2959: Magnet Cylindrical Casing
3004pz2: Brick 1 x 2 with Green Bow Tie Pattern
3004pz5: Brick 1 x 2 with Black Spider Web Pattern
3004pz4: Brick 1 x 2 with White Trapezoidal Shape Pattern
3005: Brick 1 x 1
3010pzd: Brick 1 x 4 with Black Outlined White Star Pattern
3010pzc: Brick 1 x 4 with 3 Red Vertical Stripes Pattern
3010pza: Brick 1 x 4 with Wonder Woman Logo Pattern
3010pz9: Brick 1 x 4 with Superman Logo with Black Border Pattern
3010pz8: Brick 1 x 4 with Black Abdominal Muscles Pattern
3010pzh: Brick 1 x 4 with Black Spider Web Pattern
3010pzq: Brick 1 x 4 4 with Black Squares and Black Stripe Pattern
3010pzk: Brick 1 x 4 with Supergirl Logo Pattern
3010pzj: Brick 1 x 4 with Red Stripes and Metallic Gold Circles Pattern
3010pzi: Brick 1 x 4 with Red Spider Pattern
3010pzb: Brick 1 x 4 with Black Batman Logo in Black Outlined Yellow Oval Pattern
3010pzg: Brick 1 x 4 with White Insect Pattern
3010pzf: Brick 1 x 4 with Metallic Gold Eye-Shaped Medallion Pattern
3010pze: Brick 1 x 4 with Metallic Silver Claw Necklace Pattern
3068bpz0: Tile 2 x 2 with Black Spider Web Pattern
3069bpz3: Tile 1 x 2 with Red Star with Black Border on Metallic Silver Background Pattern
3069bpz6: Tile 1 x 2 with Dark Red Lines Pattern
3069bpz7: Tile 1 x 2 with Black Brickheadz Joker Playing Card Pattern
3069bpz8: Tile 1 x 2 with Metallic Silver Claw Bracelet Pattern
3069bpz9: Tile 1 x 2 with Black Web Spider Pattern
3069bpza: Tile 1 x 2 with Green, Red and Light Bluish Grey Buttons on Metallic Silver Background Pattern
3069bpzb: Tile 1 x 2 with Light Bluish Grey Buttons on Metallic Silver Background Pattern
3245cpz1: Brick 1 x 2 x 2 without Understud with Black Undershirt, Metallic Dark Grey Clasps and Dark Bluish Grey Decorations Pattern
3245cpz2: Brick 1 x 2 x 2 without Understud with White Tie Pattern
3278: Tap 1 x 2 Spout
3496: Tap 1 x 2 Base
3496c01: Tap 1 x 2 with Light Grey Spout
3496c02: Tap 1 x 2 with Chrome Spout
3564: Animal Cow Horn 2.25L
4728: Plant Flower 2 x 2 with Hollow Stud
4869: Plane Jet Engine Centre
11477pz2: Slope Brick 31 1 x 2 x 0.667 with Dark Red Mythosaur Skull and White Background Pattern
15068pz1: Slope Brick Curved 2 x 2 x 0.667 with Metallic Silver and White Hole Pattern
15429: Animal Cat Tail
16770: Claw Wide with Clip
Update: 2019/07/03 - 2
18041: Minifig Harpoon with Smooth Bar
20482: Tile 1 x 1 Round with Pin and Pin Hole
24201: Slope Brick Curved 2 x 1 Inverted
24855: Plant Flower Stem with Bar
24866: Plate 1 x 1 with 5 Petals
25893: Plate 1 x 1 Round with Horizontal Handle Below
27263: Tile 2 x 2 Corner without Corner
28192: Slope Brick 45 2 x  1 with Cutout and without Stud
29119: Slope Brick Curved 2 x 1 with Cutout Righ
29120: Slope Brick Curved 2 x 1 with Cutout Left
30249: Slope Brick 55 1 x 6 x 5
30359a: Bar 1 x 8 with Brick 1 x 2 Curved Top End
30359b: Bar 1 x 8 with Brick 1 x 2 Curved Top End with Axlehole
30361a: Cylinder 2 x 2 x 2 Robot Body without Bottom Axle Holder
30370: Minifig Helmet Star Wars Rebel Pilot
30552: Hinge Arm Locking with Single Finger and Axlehole
30553: Hinge Arm Locking with Dual Finger and Axlehole
32059: Plate 4 x 6 without Corners
32828: Plate 1 x 1 Round with Bar
32952: Brick 1 x 1 x 1.667 with Studs on 1 Side
33291: Plate 1 x 1 Round with Tabs
34103: Plate 1 x 3 with 2 Studs Offset
41769: Wing 2 x 4 Right
41770: Wing 2 x 4 Left
43710: Wedge 4 x 2 Double Left
43711: Wedge 4 x 2 Double Right
43722: Wing 2 x 3 Right
43723: Wing 2 x 3 Left
43892: Animal Tail
47905: Brick 1 x 1 with Studs on Two Opposite Sides
52031: Wedge 4 x 6 x 0.667 Curved
53451: Minifig Helmet Viking Horn
58367: Minifig Hose Nozzle with Side String Hole
61184: Technic Pin 1/2 with Bar 2L
63868: Plate 1 x 2 with Clip Horizontal on End (Thick C-Clip)
71075a: Brick 1 x 1 x 1.667 Round
85984pz0: Slope Brick 31 1 x 2 x 0.667 with Dark Red Mythosaur Skull and White Background Pattern
87079pz2: Tile 2 x 4 with Black Cracks Pattern
87079pz4: Tile 2 x 4 with Brickheadz Seasonal Calendar Pattern
87079pz5: Tile 2 x 4 with Lego Logo and White "#LEGOSDCC" Pattern
87079pz6: Tile 2 x 4 with Black Outlined White "A" Pattern
87079pz7: Tile 2 x 4 with Metallic Silver Lines Pattern
87079pz9: Tile 2 x 4 with Brickheadz "#LEGOSDCC" "2017" Pattern
87079pza: Tile 2 x 4 with 10 Yellow Rectangles Pattern
87079pzb: Tile 2 x 4 with Lego Logo, White Star Wars Logo and Metallic Silver "NEW YORK COMIC CON 2017" Pattern
87079pzd: Tile 2 x 4 with Brickheadz Series Number "1" Pattern
87079pz8: Tile 2 x 4 with Black Spider Web Pattern
87087: Brick 1 x 1 with Studs on 1 Side
88930pz1: Slope Brick Curved 2 x 4 with Underside Studs with Yellow Arches and Circles Pattern
88930pz2: Slope Brick Curved 2 x 4 with Underside Studs with Red Trapeze and 2 Orange Ovals Pattern
91049: Plate 1.5 x 1.5 x 0.667 Round
93273: Slope Brick Curved 4 x 1 Double
93273pz0: Slope Brick Curved 4 x 1 Double with Red Star with Black Border Pattern
93273pz1: Slope Brick Curved 4 x 1 Double with Black Belt with Black Pockets Pattern
98138p0e: Tile 1 x 1 Round with Silver Dot in Thin Black Circle Pattern
98138ps5: Tile 1 x 1 Round with Dark Bluish Grey Lines in Y-Shape Pattern
99253: Minifig Lasso
Edited by Darats
