knigtonwheels Posted April 3, 2018 Posted April 3, 2018 Hello everyone, you all a talking about a ini file, i ran a search on my PC and I don't have any blueprint.ini on it. i just want to confirm, that i have all files i need. the blueprint0026 i downloaded has two folder in it (bin and native) and also 3 files (blueprint.bat, lenghts.txt and readme.txt, in the folder bin is the blueprint.jar, and the native has dll, dylib and so files in it but nowhere is a ini file. as mentioned prior, i'm not familiar with all this, but i would like to know, how to change the colors thank you Markus Quote
msx80 Posted April 3, 2018 Author Posted April 3, 2018 @knigtonwheels have you ran the program at least one? the ini files is created by Blueprint when first run. You can find it on C:\Users\<your name>\AppData\Roaming Quote
knigtonwheels Posted April 3, 2018 Posted April 3, 2018 On 4/3/2018 at 3:35 PM, msx80 said: @knigtonwheels have you ran the program at least one? the ini files is created by Blueprint when first run. You can find it on C:\Users\<your name>\AppData\Roaming Expand Thank you Quote
knigtonwheels Posted April 3, 2018 Posted April 3, 2018 (edited) On 4/3/2018 at 3:35 PM, msx80 said: @knigtonwheels have you ran the program at least one? the ini files is created by Blueprint when first run. You can find it on C:\Users\<your name>\AppData\Roaming Expand i do have one more question, in the ini file, what should be in there? i only see four lines starting with directory.open; /input; /export and save with the path on each do i just add the lines you posted above with instead of an X by the color with something like 000000 or 015GDG, what ever color i would prefer? Also, when i open a new project, the ini file is "empty", the lines i added are gone is there anywhere a thread, where this is explained Edited April 3, 2018 by knigtonwheels Quote
Tyke Posted April 3, 2018 Posted April 3, 2018 On 4/3/2018 at 4:12 PM, knigtonwheels said: i do have one more question, in the ini file, what should be in there? i only see four lines starting with directory.open; /input; /export and save with the path on each do i just add the lines you posted above with instead of an X by the color with something like 000000 or 015GDG, what ever color i would prefer? Also, when i open a new project, the ini file is "empty", the lines i added are gone is there anywhere a thread, where this is explained Expand Not explained, probably there is somewhere a hint, that what is set here, can be avoided to set manually. Just to be sure regarding the color syntax, I paste my ini file here below. There is 2 things above by @msx80 I will add soon, The width and the height. When I finish my first project, I will try to write a log of how I did. And with my 1600 part set, I decided to cut them into as many pieces as I need to create as professional PNG files, as posssible for a future to be instruction. This result in: I do many-many new projects, somethime 1 BP project produces only 1 next page in my future-to-be-instruction, therefore I need to set the width anf height from time to time. With the above ini file settings that will save me some valueable time. directory.open=C:\Users\myusername\Documents\LEGO Creations\BluePrint directory.open=C:\Users\myusername\Documents\LEGO Creations\BluePrint directory.input=C:\Users\myusername\Documents\LEGO Creations\Models\Project directory.input=C:\Users\myusername\Documents\LEGO Creations\Models\Project page.background=C:\Users\myusername\Documents\_Priv\Lego\SW\Blueprint0026\bg.jpg directory.export=C:\Users\myusername\Desktop\LEGO\Próba\PNG page.color.0=#ebf4eb directory.save=C:\Users\myusername\Documents\LEGO Creations\BluePrint I try to insert 1 page of the instruction here. I needed to scale it down to be less, then 0.1 MB in size here. Quote
Darthmarty Posted April 6, 2018 Posted April 6, 2018 This might help others that come across this issue, without having to read through 24 pages to figure it out - if you are getting an error message when you first try out this program - try downloading the most recent version of Java. I was getting an error message when I first tried to open the "blueprint.bat" file and got this error message : 'java' is not recognized as an internal or external command, operable program or batch file. Press any key to continue . . . When I press a key it just closes. I saw some discussion about Java earlier in the thread, and sure enough after updating it, the program opened properly. Quote
knigtonwheels Posted April 6, 2018 Posted April 6, 2018 On 4/3/2018 at 8:24 PM, Tyke said: Not explained, probably there is somewhere a hint, that what is set here, can be avoided to set manually. Just to be sure regarding the color syntax, I paste my ini file here below. There is 2 things above by @msx80 I will add soon, The width and the height. When I finish my first project, I will try to write a log of how I did. And with my 1600 part set, I decided to cut them into as many pieces as I need to create as professional PNG files, as posssible for a future to be instruction. This result in: I do many-many new projects, somethime 1 BP project produces only 1 next page in my future-to-be-instruction, therefore I need to set the width anf height from time to time. With the above ini file settings that will save me some valueable time. directory.open=C:\Users\myusername\Documents\LEGO Creations\BluePrint directory.open=C:\Users\myusername\Documents\LEGO Creations\BluePrint directory.input=C:\Users\myusername\Documents\LEGO Creations\Models\Project directory.input=C:\Users\myusername\Documents\LEGO Creations\Models\Project page.background=C:\Users\myusername\Documents\_Priv\Lego\SW\Blueprint0026\bg.jpg directory.export=C:\Users\myusername\Desktop\LEGO\Próba\PNG page.color.0=#ebf4eb directory.save=C:\Users\myusername\Documents\LEGO Creations\BluePrint I try to insert 1 page of the instruction here. I needed to scale it down to be less, then 0.1 MB in size here. Expand @Tyke thank you for the explanation. my problem is more like, i really don't have experience with this and when i add a line to the ini file, as soon i open one of the LDD set i drew, it will be empty, meaning, only the first four line itmes are there, but what i added and saved is gone what i'm doing wrong. i would like to change the background color to a blue or green or anything else than white i have to say, i'm very organized with my stuff, so every project is in its own folder with and PNG or JPGs i did, or any other files i needed to create it so every project i open, i open from a different folder, might these be an issue? thank you Markus Quote
Tyke Posted April 6, 2018 Posted April 6, 2018 hello @knigtonwheels I am not really a support specialist on this. Can you please detail, what OS is you computer, in which directory you ini file is, and where those project folders are? I am not sure, if this helps, but if it is a Windows, I might can help. The ini file is 1 file and has to be in a proper place, not moved to any other place, full Access might needed to this file. Project folder can be anywhere, as you always need to open it, from whatever folder they are, when you try to use Blue Print. Quote
knigtonwheels Posted April 6, 2018 Posted April 6, 2018 (edited) On 4/6/2018 at 1:25 PM, Tyke said: hello @knigtonwheels I am not really a support specialist on this. Can you please detail, what OS is you computer, in which directory you ini file is, and where those project folders are? I am not sure, if this helps, but if it is a Windows, I might can help. The ini file is 1 file and has to be in a proper place, not moved to any other place, full Access might needed to this file. Project folder can be anywhere, as you always need to open it, from whatever folder they are, when you try to use Blue Print. Expand Hell @Tyke, yes it is a windows 10, the files a stored in my one drive folder, the reason for this to work from all my computers, Home, work, etc. the ini file is in the roaming folder under appdata after i send my last post, i played a bid more, the page.color.o=#?????? stays in , but only on the top of the ini file, but when i open BP it wouldn't give me any other background color than white just opened it again and page.color went back to #FFFFFF Edited April 6, 2018 by knigtonwheels new development Quote
supertruper1988 Posted April 6, 2018 Posted April 6, 2018 On 4/6/2018 at 1:30 PM, knigtonwheels said: Hell @Tyke, yes it is a windows 10, the files a stored in my one drive folder, the reason for this to work from all my computers, Home, work, etc. the ini file is in the roaming folder under appdata after i send my last post, i played a bid more, the page.color.o=#?????? stays in , but only on the top of the ini file, but when i open BP it wouldn't give me any other background color than white just opened it again and page.color went back to #FFFFFF Expand You will need to add the line to all of the computers that you have run blueprint on. Quote
knigtonwheels Posted April 6, 2018 Posted April 6, 2018 On 4/6/2018 at 2:59 PM, supertruper1988 said: You will need to add the line to all of the computers that you have run blueprint on. Expand @supertruper1988 thank yo so much for the hint. how do i do the background color, tried page.background.0=#any color, but nothing, did on both PCs or is it color instead of page thank you Quote
Tyke Posted April 6, 2018 Posted April 6, 2018 (edited) @supertruper1988 is right, ini file should be treated as part of the BP installation, which can be different at each computer, but should be kept identical, if you expect to see the same results. I think your OneDrive case makes the situation a bit more complicated, so I would highlight some neuralgic point: - You ini file should be edited by notepad. This way it is ensured, that there is no hidden TABS, and other invisible characters in the file, that makes it useless. - Please check on the syntax, page.color.o is a typo? it should be 0 (zero). - If you have OneDrive folder synced to your computer, I pretty assume, that the path to the folders contain spaces. As you can see in my way above example, I carefully create my folders to avoid such situation a path has a space in it. Also it is with the username. Probaby it can be worked around by encapsulating the path to qoutes " " or ' ', have not tested it. - What is more important, that BP is using LDD database. It is highly recommended to be updated to the same version, and I would install the same version and bit of Java as well on all affected computers. @msx80 did not specify page.background.0 Such things are not like what we figure out. Only those parameters exist in the ini, that he explicitely defined and refers to in the BP. You may try to use page.background as he listed, but not give a value of a path to a file, but give a value of a #color code. If that is not working, it is just simply not in use by him. Edited April 6, 2018 by Tyke Quote
knigtonwheels Posted April 6, 2018 Posted April 6, 2018 On 4/6/2018 at 3:31 PM, Tyke said: @supertruper1988 is right, ini file should be treated as part of the BP installation, which can be different at each computer, but should be kept identical, if you expect to see the same results. I think your OneDrive case makes the situation a bit more complicated, so I would highlight some neuralgic point: - You ini file should be edited by notepad. This way it is ensured, that there is no hidden TABS, and other invisible characters in the file, that makes it useless. - Please check on the syntax, page.color.o is a typo? it should be 0 (zero). - If you have OneDrive folder synced to your computer, I pretty assume, that the path to the folders contain spaces. As you can see in my way above example, I carefully create my folders to avoid such situation a path has a space in it. Also it is with the username. Probaby it can be worked around by encapsulating the path to qoutes " " or ' ', have not tested it. - What is more important, that BP is using LDD database. It is highly recommended to be updated to the same version, and I would install the same version and bit of Java as well on all affected computers. @msx80 did not specify page.background.0 Such things are not like what we figure out. Only those parameters exist in the ini, that he explicitely defined and refers to in the BP. You may try to use page.background as he listed, but not give a value of a path to a file, but give a value of a #color code. If that is not working, it is just simply not in use by him. Expand @Tyke thank you so much for your help and explanation. the file path is without any spaces and yes, it was a type in the thread now i got it working, since i put the same path on both PCs just hopped, to be able to change the color of the parts background Quote
Tyke Posted April 6, 2018 Posted April 6, 2018 That is all reasonable, this is why I originally asked @msx80 for all the possible parameters. I hoped, at least all the parameters, that are in the Page Settings Dialog boksz has in BP can be managed from ini, but this is not the case. Imagine, that he might refer to the white color of parts background in his BP all over at lets say 30 places in the code. He needs to replace these codes to refer to page.whatevercode he wants and the put it in the ini file. All such improvments do not give any new feature of such to the application, just makes some of us easier to work with. This results in a low priority. Quote
brickdater Posted April 6, 2018 Posted April 6, 2018 @msx80 Hi msx80, This software is incredible, and I've used it to create instructions for a number of my builds. I have one question though: Is there a particular zoom number that allows for perfect outlining of parts? It seems that no matter what number I try, there's always an edge or two that doesn't show up around a stud. Thanks! Quote
greenbutterfly42 Posted April 14, 2018 Posted April 14, 2018 Hi @msx80, I'm absolutely impressed by your software. I was pointed in it's direction by a friend, because I have a cathedral designed in LDD that I'm wanting to build slowly, but LDD couldn't handle it because I had to split it into 3 files, each with around 30,000 bricks (yeah, you read that right). Your software opened up the files and generated the instructions from the defaults in less time than LDD takes to open them! However, I've found a couple of issues and have a couple of suggestions. Firstly, the size of my models mean that every step generates a "bounding box overflow" error. Is there a way to change the zoom level or size or something? To give you an idea, the baseplates are a 3x2 grid of the 48x48 stud plates... and I'm assuming this error is the cause of the rendering issue visible in the attachment??? Secondly, inside the cathedral are some chandeliers hanging from chain lengths, but the chains are added in the first step despite there being nothing to attach them to at the time (you can see them as the vertical lines in the attachment)... I understand I can manually relocate them to later on in the build, but it'd be great to see them handled better by default I'd love to see some preferences or something, that allow me to set a default path for the tool to look for my models. Also to set some kind of limit on the number of pieces added per step in the default generation. My models have a couple of dozen per step. Thanks again though for your awesome efforts! Quote
Iperial_Fleet_Commander Posted April 22, 2018 Posted April 22, 2018 I'm having a bit of a problem. I downloaded the file, ran it, and my security system blocked it? Even after I allowed it, it still wont run. Any fixes? (I'm using a windows 8 PC.) Quote
GrahamSlam Posted April 22, 2018 Posted April 22, 2018 On 4/22/2018 at 2:11 AM, Iperial_Fleet_Commander said: I'm having a bit of a problem. I downloaded the file, ran it, and my security system blocked it? Even after I allowed it, it still wont run. Any fixes? (I'm using a windows 8 PC.) Expand Yeah, months ago my antivirus detected multiple trojans in several of the files. The .dll files in the software appear to contain viruses; I brought this up months ago. Apparently the software creator hasn't reuploaded the file, as it still contains malware. Quote
Iperial_Fleet_Commander Posted April 23, 2018 Posted April 23, 2018 On 4/22/2018 at 2:41 PM, GrahamSlam said: Yeah, months ago my antivirus detected multiple trojans in several of the files. The .dll files in the software appear to contain viruses; I brought this up months ago. Apparently the software creator hasn't reuploaded the file, as it still contains malware. Expand Well that's concerning. I hope I didn't doom the computer. (It's a family computer.) Quote
msx80 Posted April 23, 2018 Author Posted April 23, 2018 i'm pretty sure the software doesn't contain malware, it's just that the libraries i'm using (lwjgl) are known to give some false alarm. If you want, you can replace the dll i'm shipping with some from the official distribution (i'm using version 3.1.0 but should work with any 3.1.x). You can find it here under "/lwjgl/release/3.1.0/windows". Lwjgl is used by hundreds of projects so i'm sure it's safe to use. Quote
Ben Andrews Posted April 23, 2018 Posted April 23, 2018 On 4/22/2018 at 2:41 PM, GrahamSlam said: Yeah, months ago my antivirus detected multiple trojans in several of the files. The .dll files in the software appear to contain viruses; I brought this up months ago. Apparently the software creator hasn't reuploaded the file, as it still contains malware. Expand I'm pretty sure it's called a "false positive". I've come across is a few times running open source or indi designer programs that rely or run on certain frameworks. That's really all I know. But I also figure someone who puts in as much work and functionallity into a piece of free software for a massive community that they are apart of, would probably not steer us wrong! Thanks MSX80, your the shiz-nit! Quote
olesolo Posted April 23, 2018 Posted April 23, 2018 Hi! Where I can find the link to the latest version? Thanks Quote
Whovian41110 Posted May 2, 2018 Posted May 2, 2018 Hey @Malou my version of the Mac version doesn't work. I get this error: Quote "Header checksum broken. Store was not closed correctly and might be corrupted. Use ' DBMaker.checksum.HeaderBypass() ' to recover your data. Use clean shutdown or enable transactions to protect the store in the future." Expand My specs are as follows MacBook Pro (15-inch, 2017) Processor: 2.9 GHz Intel Core i7 Memory: 16 GB 2133 MHz LPDDR3 Startup Disk: Macintosh HD Graphics: Radeon Pro 560 4096 MB Intel HD Graphics 630 1536 MB Quote
dspoonage Posted May 6, 2018 Posted May 6, 2018 First of all love the program! I have an error on a model that has taken hours to generate instructions, it's still incomplete but I wanted to export a PDF to copy complicated assemblies on an adjacent side which I have been doing as there are similar assemblies. When I have come to (Re) Generate from steps i would say 90% of the steps seem to work where others generate an error. I have searched and searched for ghosted sub-groups? but I may be overlooking something. from what I can make out there are at least 2 assemblies which generate the errors X1397 & X1172. I have included a link to the blue-note file & error log as below via Google drive. https://drive.google.com/file/d/1_79-jCq_i7dTNDnzj8w_s-g2a2yxQsXu/view?usp=sharing Hopefully somebody can help, as I would be gutted to lose it all to not be able to generate steps. Quote Rendering assembly x6 Total mem after new page: 2857893888 Rendering assembly x10 Total mem after new page: 2857893888 Rendering assembly x1172 Rendering assembly x10 Total mem after new page: 2857893888Rendering assembly x1397 Rendering assembly x1172 Rendering assembly x0 java.lang.ArithmeticException: / by zero at blueprint.b.a.e.l(Unknown Source) at blueprint.scene.bi.StepBox.a(Unknown Source) at blueprint.a.d.a(Unknown Source) at blueprint.a.c.a(Unknown Source) at blueprint.a.c.b(Unknown Source) at blueprint.a.c.a(Unknown Source) at blueprint.a.c.b(Unknown Source) at blueprint.a.c.a(Unknown Source) at blueprint.a.c.b(Unknown Source) at blueprint.a.c.a(Unknown Source) at blueprint.Blueprint.a(Unknown Source) at blueprint.a.h(Unknown Source) at blueprint.a.a.t.a(Unknown Source) at blueprint.a.a.a(Unknown Source) at blueprint.Blueprint.doReflowButton(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at sun.reflect.misc.Trampoline.invoke(Unknown Source) at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at sun.reflect.misc.MethodUtil.invoke(Unknown Source) at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1769) at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1657) at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191) at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74) at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49) at javafx.event.Event.fireEvent(Event.java:198) at javafx.scene.Node.fireEvent(Node.java:8411) at javafx.scene.control.Button.fire(Button.java:185) at com.sun.javafx.scene.control.behavior.ButtonBehavior.mouseReleased(ButtonBehavior.java:182) at com.sun.javafx.scene.control.skin.BehaviorSkinBase$1.handle(BehaviorSkinBase.java:96) at com.sun.javafx.scene.control.skin.BehaviorSkinBase$1.handle(BehaviorSkinBase.java:89) at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:218) at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191) at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74) at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54) at javafx.event.Event.fireEvent(Event.java:198) at javafx.scene.Scene$MouseHandler.process(Scene.java:3757) at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3485) at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762) at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2494) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:394) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:295) at java.security.AccessController.doPrivileged(Native Method) at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$353(GlassViewEventHandler.java:432) at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:389) at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:431) at com.sun.glass.ui.View.handleMouseEvent(View.java:555) at com.sun.glass.ui.View.notifyMouse(View.java:937) at com.sun.glass.ui.win.WinApplication._runLoop(Native Method) at com.sun.glass.ui.win.WinApplication.lambda$null$147(WinApplication.java:177) at java.lang.Thread.run(Unknown Source) Expand Quote
supertruper1988 Posted May 6, 2018 Posted May 6, 2018 On 5/6/2018 at 9:50 PM, dspoonage said: First of all love the program! I have an error on a model that has taken hours to generate instructions, it's still incomplete but I wanted to export a PDF to copy complicated assemblies on an adjacent side which I have been doing as there are similar assemblies. When I have come to (Re) Generate from steps i would say 90% of the steps seem to work where others generate an error. I have searched and searched for ghosted sub-groups? but I may be overlooking something. from what I can make out there are at least 2 assemblies which generate the errors X1397 & X1172. I have included a link to the blue-note file & error log as below via Google drive. https://drive.google.com/file/d/1_79-jCq_i7dTNDnzj8w_s-g2a2yxQsXu/view?usp=sharing Hopefully somebody can help, as I would be gutted to lose it all to not be able to generate steps. Expand I just opened your file on my mac and had it generate steps with no issues. Actually I cant haha. I think your file is too big. I can definitely see some places to improve it but we can PM about that for sure. Quote
