I am making a mural using 8 - 48x48 gray base plates.
I do not want to glue them down as this will be a one time one day showing. (last minute idea from my paster) I do not plan on doing a traditional mural but more of a loose free form with bricks and pieces.
Trying to figure out the best way to keep things together. I am thinking of making a frame on a piece of wood that I can slide the connected base plates into then having the whole thing rest on a slightly angled stand?
Any thougts
Thanks
If you're displaying it vertically then double-sided tape won't do the trick and will get messy. What works well, though, is 3M Command Adhesive strips - you can buy packs of just the strips without hooks or anything and they're pretty cheap, and they hold very well and come off the Lego nice and clean. Good luck, and maybe share some pictures of your project when it's done! :classic:
oh i hadent thought of comand strips ill try that at this point im planning it to be a bit less than a ninty degree angle maybe 80 or 75 degrees its going to be of a tree so we will see how it works
