colmoore Posted March 7, 2015 Posted March 7, 2015 (edited) Hi all, I've just noticed you can't seem to get a stick into part 4729 (2x2 brick with vertical snap) Any ideas please? Edited March 7, 2015 by Superkalle Updated title to make it a bit more clear Quote
Superkalle Posted March 7, 2015 Posted March 7, 2015 It's because the physical version of the does not allow a bar to inserted into the hole. At least in the bricks I have at home it won't fit (although I did have one with a very, very tight fit). Note that sometimes there can be many physical versions (revisions) of a brick even with the same DesignID. In those cases, maybe some old version has an "open" hole, and then maybe a later mold version does not have it. In these cases, LDD normally uses the latest version to decide the functionality of the digital brick. Quote
___ Posted March 13, 2015 Posted March 13, 2015 On 3/7/2015 at 8:03 AM, colmoore said: Hi all, I've just noticed you can't seem to get a stick into part 4729 (2x2 brick with vertical snap) Any ideas please? Probably because that is considered by LDD as illegal connection? See, in real life LEGO I can stick any brick into holes of technic perfored bricks and it sticks as hell,,but try it in LDD and no success - you would need to stick some 1x1 bricks into every single hole in the technik brick and only then you can apply the normal brick to it, you see? So who knows? Maybe there is some "trick" for you brick too... Quote
