How do I determine the torque bias on a Torsen diff (how much more torque the greater-traction wheel gets than the lower-traction wheel)? Thanks. I'm most curious about this one (and how much torque and rotational speed it could handle):
http://www.brickshel...ry.cgi?f=259949
As far as I can tell, neither that nor any of the other "Torsen" diffs made of Lego are actually proper Torsen diffs. They don't sense torque; instead the diff locks when the the angular position of the two shafts differs by enough. They only unlock if that angular difference is reduced. In other words, there is no torque bias because this is a locking, not a limited-slip, differential; and the locking is based on relative angular position, not angular speed or torque.
True mechanical torque-sensing differentials seem to require helical gears, which Lego does not make. There are simple ways of making limited-slip differentials with rubber bands connecting the half-shafts to a common third shaft, and those work reasonably well at low torque.
I'm fairly certain that in order to have any kind of torque bias, there needs to be a difference in the gearing of the axles on either side of a differential. Also, this differential is not strong at all, and will break apart as soon as it locks up. I speak from personal knowledge, as I have build this particular design, and have tested it.
If you want a limited slip differential, Thirdwigg has build some in his trial trucks.
6793200719_140d534b8b.jpgKenworth T55 Driveline by thirdwigg, on Flickr
However, from my experience, differentials in most kinds of Lego trial trucks are rather counterproductive, even if they are limited slip.
Edited by Saberwing40k
The small size is super impressive! How much torque or rpm can it handle, though?
It's not that very small. I was unable to damage it with torque so far. Keep in mind that this is a complex 3D printed part, it may require some filing before it works properly.
If I have 5 L motors hard-coupled, geared from between 1:1 and 1:9, would Efferman's Torsen Diff be damaged? Also, would you recommend it in a "supercar", compared to a lockable diff?
Edited by TheLegoExpert
Your guess is as good as mine. And I'm not sure you need a Torsen or a lockable driff in a supercar, I mean supercars don't really go off-road.
Audi has used it since 1986 http://www.audi-tech...en-differential :)
Yeah, but what works for Lego cars and what works for real cars are very different things. Most Lego cars do not need any kind of advanced suspension geometry, or brakes, for that matter.
Also, like Sariel said, I have never seen a Lego supercar encounter a slip or odd traction situation that would require a limited slip differential.
