First time posting here so if this is in the wrong forum I apologize.
I'm in the process of designing this church: http://i.imgur.com/dY5Ovfd.jpg
In the image I have an arrow pointing to the part of the church where I'm struggling to design. Do you have any suggestions on how to accomplish this? The roof is the trickiest part for me. Is this even possible? What would you do? The width of the church is going to be 32 units so it won't be a huge church.
Thanks for the help!
Welcome, dcht,
One of the ways is to use four angled plates:
http://www.bricklink...tem.asp?P=54383
and
http://www.bricklink...tem.asp?P=54384
To get the right angle of the roof, use a few hinges/rocker plates.
For instance 3937 and 6134 or 3938.
There are smaller angled plates as well, if necessary.
You can use the facade top of 10185 (Green Grocer) as an example. The lxf is here:
http://www.eurobrick...525#entry926429
Edited by Withacee
Welcome, dcht,
and
Thanks! Any ideas on the angled wall? I was debating between 6039346 and 4227507. I would also need to be able to put a window in, which is why I'm leaning towards 4227507.
If you need windows, the hinges (either as plates or as bricks, both are available) are usually better.
Modified facet bricks come in different widths:
http://www.bricklink.com/catalogList.asp?q=Brick,%20Modified%20Facet
Advantage of these is a nice smooth outer surface.
You can still combine them with windows in combination with the hinge bricks, but it never looks perfect.
Disadvantage is the fixed angle; as opposed to hinges which can, well, hinge :sweet:
It looks like a great project.
Good luck, and we look forward to seeing some of your work!
