The more I look at your schematic, the more I am tempted to try and build it. Cavegod's has always been a bit ambitious for me, but 4k pieces is doable.
In terms of your design, do you think the 8 2x2 connection points to the undercarriage is enough to support the weight of that cockpit being that far forward?
Probably not but i was planning on beefing up the connections anyway, the plan was to get as much external detail as possible till i was happy then work on the internals, i just never got time to finish it. Feel free to work on the design, it would be fantastic to see it built :classic:
Im still waiting for parts from BL, meanwhile updated movable head (thanks to All in Reflexes).
Im also working on side plates of head amour to avoid use of turntables.
Edited by La Chupacabra
Little announce of upcoming pictures:
Evil Imperial Crew
New version of drive motor (I think that Dark Bluish Gray wheels look good):
A small piece of advice.
Your AT AT will be very heavy, as you are using bricks for the outside.
If you want the legs to be poseable, or, at least, be sure that your AT AT will not fall frontwards or rearwards, I suggest putting double hinges in all the leg joints. My lighter AT AT suffered a catastrophic accident because the "shoulders" (the joints which were in the top of the front legs) were not able to withstand a push from behind and the vehicle collapsed. Exactly like in Episode V where an AT AT is shot down by a Snowspeeder...
Best regards.
Thanks for your advice. It is hard to add another hinge - in that case leg or hip would have to be thicker. Im considering also non movable version... :sceptic:
After New Year i will post some photos of four legs. Now i have finished two legs and two another are half build.
In next week i will post some photos of 100% finished four legs. I have also ordered all parts for head :wink: When head will be completed i will be in middle of my MOC. So far (with head pcs) i have spent about 450€ but i have a lot of spare parts for body and for my future MOCs (AT-ST) :blush:
Empire is enlisting but still one crew member is missing :wink::
Tree legs (im waiting for missing parts for four leg):
Also i have idea for new foots (similar to cavegod version).
I have two hips and next two are missing parts so Im waiting again :sick:
this is gonna look great when its finished... im thinking about building one too because i believe Lego wont release UCS AT-AT anytime in the near future. And if they do i think it will come out looking like the Sandcrawler which i did not like. Way too many studs.
