Purists, sharpen your pitchforks ;)
Many thanks to Efferman for designing such interesting elements and for support he provided. While I don't intend to use 3D-printed elements regularly, it's interesting to see the possibilities they open and the performance they offer. Who knows, maybe TLG will actually wake up and make some new pieces of their own?
Photos & reading: http://sariel.pl/2014/10/dune-buggy/
Hi EB,
This is my first proper post here after several months of lurking in the background.
While I am essentially a purist, it is great to see Efferman's amazing creations put to use in a great MOC. I have been watching the progress of these parts and have been amazed by the creativity. Hopefully if enough are put to use then TLG might start to review their own parts catalogue as it is becoming clear that some of their shocks, diffs, linear actuators etc. are good enough for larger MOCs and even some of their own sets (the LA's in 42009 are way too small).
This is a great Hamster scale MOC Sariel, while the bounce in the rear shocks may not be great for handling and control, it still looks pretty cool.
I really, really like that heavy-duty differential and the way it's assembled. Let's hope TLG pays attention.
I guess you mean aren't good enough :laugh:
Edited by jantjeuh
I still can't decide if I like most about the buggy or the video itself ... I'm a purist (by now), some of the Efferman's parts seem to be really really interesting!!
Anyway, funny Buggy!!
not a fan of the look of the springs - but they do handle beautifully....
the diff is excellent and the 5L beams well why not - 6l 7l 8l should be available in all sizes
I am confused as to how mounting the springs upside down changes how they handle. The force it takes to compress or stretch is the same and is based on its spring constant, right? Anyway, great looking buggy, it looks fun to drive too!
Tim
I'm not sure, actually. They're much easier to compress than to stretch - perhaps because of how they're shaped you can stretch them much farther than you can compress them.
Edited by Sariel
I'm finding myself both intrigued and puzzled by the heavy duty diff. While I'm sure that adding 4 spider gears will make the diff itself much stronger, the whole ring gear is still driven by a single 12 tooth bevel gear, so the weak link seems like it is just the same as it was before. Can this really handle more torque than a regular diff? Has anyone tested them to failure to find out? It seems like as long as the failure of a single bevel tooth renders the system inoperable, then the strength of the system as a whole stays the same.
Good point Blakbird. Wasn't the middle spider gear (the freely rotating one) in the official differentials always the weakest link? I guess the one driving the custom differential is now the next-weakest one.
i dont think that the 12 tooth, which drives the 36 tooth, is really in danger, because there is 3:1 reduction between both gears. and when the torque is to high for the bevel gear then us the spur option of the 36 tooth
I would say "nothing that normal lego parts couldn't do"
How would you do a suspension with the performance this buggy got by stretching springs? I don't think you can get the same effect stretching elastic bands.
I assume you didn't read Sariel's words then! Originally the springs were designed to work as a normal compressed springs, but as they don't do their job well, Sariel had to invert them and use them as "extended springs". It's just a casuality, plus you can really use elastic bands if you want to!
happy days...
stretching these springs makes them behave linearly
compressing them, well they just pop sideways all of a sudden
they would need two pin holes at each end to stop that or enclosed somehow
I did read his blog post, but I don't think elastic bands would behave that well.
Off course they would not! but if you create I nice linkage and connect it with rubber bands you can come very close to.
Plus, who said we necessary need to imitate or come closer to those "inverted springs"?? According to your way of thinking we shoudl use real OHLINS shock absorber in our mocs...just because they are the best in world! :tongue:
I think we should take the challange of building what we can with what we have....... otherwise imagine if a RC model maker uses some LEGO parts in his world. LEGO is LEGO, then there is the rest....why do we mix them? :blush:
No hard feelings my friends..
Edited by TheItalianBrick
People are testing parts which have been custom made to make their MOC's better, they are clearly not a purist like you in doing this, I too am a purist however, I do like to see how custom parts can transform an MOC :classic:
