All you need to do is replace the train bases with normal plates, making sure you've remembered to include a hole for the bogie's pin (normally a technic plate), and enough space above where the bogie's pin is for the loco to rest naturally on the top of the bogie.
It's not a bad idea to get used to not relying on the standard train bases, because although useful, they prove very restrictive on a lot of the rest of your design.
Here is an example of Rediums suggestion. Just normal plates on the bottom and a Technic plate with holes to mount the boogie. There is no side wall to limit the boogie's pivoting movement.
