Sariel Posted September 17, 2014 Posted September 17, 2014 Guys, I know a lot of you have delved into the area of tires from RC models that fit LEGO rims. It's unknown territory for me, so I'd like to ask for suggestions: I'm looking for tires that would match the look of Tumbler's rear tires. Ideally, they should be about 13 studs (104mm) in diameter, 6 studs (48mm) wide and fit some unmodified black LEGO rims. Thanks! Quote
Doc_Brown Posted September 17, 2014 Posted September 17, 2014 (edited) I reckon the closest you will get are Ansmann 1.9" tire which is what I use for a lot of my mocs as they are awesome tires! Measuring the tire in front of me I get 106mm dia, with a width of 37mm tho. Any 1.9" should fit the rim you are using tho. Hope that helps. Or perhaps this would work better. http://store.rc4wd.com/Rock-Crusher-II-XT-19-Tires_p_688.html Edited September 17, 2014 by Doc_Brown Quote
Nalyd997 Posted September 17, 2014 Posted September 17, 2014 If you search 1.9" rc tires on ebay you can pickup a set of 4 from china for around $20 free postage. They are nearly identical to the tumbler's tread surprisingly. They just about fit the rim in width but are a few mm off, however, they can be stretched a little but it deforms slightly. They also have foam inside. Here is the link: http://pages.ebay.com/link/?nav=item.view&alt=web&id=191238696068 As said before ansmann are also good but they are more expensive. Another option is axial ripsaws which look awesome VK technic uses them. Hoped this helped:) Quote
Rockbrick Posted September 17, 2014 Posted September 17, 2014 there is a thread on 3rd party tyres for lego rims - a quick search will help you find it soon enough... Quote
aol000xw Posted September 17, 2014 Posted September 17, 2014 Those are 96mm, too small. I got a similar set and don't fit well. Look for the 106mm ones. Quote
Sariel Posted September 17, 2014 Author Posted September 17, 2014 (edited) These Rock Crushers do look mean, but I think the edges are shaped differently from Tumbler's. If you search 1.9" rc tires on ebay you can pickup a set of 4 from china for around $20 free postage. They are nearly identical to the tumbler's tread surprisingly. Wow, these look amazingly accurate, thanks! Those are 96mm, too small. I got a similar set and don't fit well. Look for the 106mm ones. You mean they don't sit on the LEGO rim that well? I will look for the larger ones, thanks. In any case, I suppose too small is better than too bit - I can always try to stretch them a bit. there is a thread on 3rd party tyres for lego rims - a quick search will help you find it soon enough... Yes sir, I'm aware of this thread, as well as of the fact that it's 15 pages long. Hence my quick question for a few suggestions. PS. Looking at some blueprints, these tires can be even 120 mm big. Edited September 17, 2014 by Sariel Quote
aol000xw Posted September 17, 2014 Posted September 17, 2014 (edited) 1.9 isnt an exact match for Lego rims hence the tire needs to stretch. 96mm is smaller has less rubber to properly stretch and scales to a bit too narrow tire to properly sit on both sides of the rim... whatever, see it yourself. 106 vs 96 Edited September 17, 2014 by aol000xw Quote
Sariel Posted September 17, 2014 Author Posted September 17, 2014 Yeah, the 106 looks better, definitely, I'm just having a hard time finding it at eBay. Quote
aol000xw Posted September 17, 2014 Posted September 17, 2014 (edited) Really better! btw... http://www.ebay.com/...sd=221494186331 Edited September 17, 2014 by aol000xw Quote
Balrog Posted September 17, 2014 Posted September 17, 2014 How big are they in comparison to the Unimog tires? Quote
aol000xw Posted September 17, 2014 Posted September 17, 2014 The Unimog one is 94mm, almost exactly like the left one in diameter. Quote
Mikuri Posted September 17, 2014 Posted September 17, 2014 Anyone has tested some "slick" tires? And thanks aol000xw for the ebay link, I might order those soon :D! Quote
PROlego Posted September 17, 2014 Posted September 17, 2014 I can't answer anything, but I think it will have been better to ask that in the 3rd party tyres topic (not to search it by yourself, but to post this) so we can have all info in one place. Won't it be better to merge the topics? Quote
Black-Build Posted September 17, 2014 Posted September 17, 2014 But like Sariel already said, then you'll have to search in 15 pages... Quote
gmshades Posted September 17, 2014 Posted September 17, 2014 Sariel, I bought a set of tires from Ebay, and posted pictures in another forum, but I'll add them here as well. Vaterra VTR41004 1.9 Interco SS TSL Tire (2) SlickRock I put them on the actual model, and they look awesome! Same dimensions as the unimog tires by within a mm. Quote
Sariel Posted September 17, 2014 Author Posted September 17, 2014 Yeah, Tumbler is an option if I can get the rear wheels right. Thanks for suggestions, some of the stuff you liked is sold out already. How about these? The tread looks right to me, anybody has these? http://www.ebay.com/itm/4-x-Rubber-Tyre-108mm-Tires-Sponge-Insert-RC-1-10-Black-Rock-Crawler/161320322568?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D24934%26meid%3Df0d26ebe86924558a142941f9c382d8d%26pid%3D100011%26prg%3D10514%26rk%3D6%26rkt%3D10%26sd%3D221494186331 Quote
aol000xw Posted September 17, 2014 Posted September 17, 2014 (edited) Edit: I am talking about gmshades ones Those are 96x35 same size as the ones Nalyd997 linked and the smaller ones in my pictures. I guess that is why in the top view yours look a bit too stretched. However unlike mine even if stretched those seem to fit, perhaps due to a softer rubber or a slightly bigger inner diameter? So I stand corrected, 96x35 isn't out of the question, just a risky bet perhaps. Yeah, Tumbler is an option if I can get the rear wheels right. Thanks for suggestions, some of the stuff you liked is sold out already. How about these? The tread looks right to me, anybody has these? http://www.ebay.com/...sd=221494186331 All these chinese tires look the same to me http://www.ebay.com/itm/4PCS-RC-1-10-Model-Car-Climbing-Rock-Crawler-Rubber-108mm-1-9-Tires-Tyre-7032-/171460853766?pt=Radio_Control_Parts_Accessories&hash=item27ebdd0006 Edited September 17, 2014 by aol000xw Quote
sm 01 Posted September 17, 2014 Posted September 17, 2014 Really better! btw... http://www.ebay.com/...sd=221494186331 ...Thanks for suggestions, some of the stuff you liked is sold out already. Thanks for suggestion aol000xw! I managed to buy them before they were sold out. Quote
Blakbird Posted September 17, 2014 Posted September 17, 2014 The real Tumbler uses "Super Swampers" made by Interco. Plenty of R/C tire manufacturers make this very tire, so just search for Interco Super Swamper and buy one with the right inside diameter. Quote
Sariel Posted September 17, 2014 Author Posted September 17, 2014 just search for Interco Super Swamper and buy one with the right inside diameter. Good idea. I found these, 121 mm with foam: http://www.ebay.pl/itm/GOMME-INTERCO-TSL-1-9-XL-DIAMETRO-PIUGRANDE-MESCOLA-G8-PROLINE-GPPRL1197-14-GO-/301308042909?pt=Modellismo_Dinamico&hash=item46275bde9d&_uhb=1 Any idea if they fit any LEGO tires? Quote
efferman Posted September 17, 2014 Posted September 17, 2014 the risk that it doesnt fit is very low. 1.9 inch tires does have a smaller inner diameter than the unimog tires so the have a very good contact to the rim. Quote
Sariel Posted September 17, 2014 Author Posted September 17, 2014 Thanks. I may need to stretch them a bit wider to match the Tumbler's look, I think. Quote
aol000xw Posted September 17, 2014 Posted September 17, 2014 1.9 refers to the inner diameter and even if It isn't perfect as Lego rims are 56mm the wheel squezzes a bit and fits. The perfect match would probably be 52 mm inner diameter tire instead of 48mm (1.9") but it works. However those are 44mm wide vs 34mm of the Lego rims, but wider isn't necessarely so bad, I think they can probably fit but is hard to tell. Quote
