MLCAD Submodel Tutorial
  • Please log in to reply
36 replies to this topic
#1 ZCerberus
ZCerberus
  • Not good at planning idiot cowboy parties
    Member: 1043
    Country: USA
Posted 20 February 2007 - 09:26 PM
The use of his idea was approved by Mr. Phes.
To see and discuss his Sentry Box, go here.   Phes's Imperial Sentry Box
Several users who are just beginning with MLCAD may find it annoying to have to move 100 pieces just because you forgot a brick in the middle of the model, or to try to rotate 100 pieces in the same direction, but fear not, because a solution awaits you!  I found that one of the greatest things in MLCAD is submodel or multi-part builds.  This little tutorial is to show you how to use that feature!
First things first, what is a submodel?  It is a model inside a larger model.  Think about when you are working on a LEGO set and the instructions have a small breakout box with a submodel, like a wing on a TIE Fighter, or a cannon on a pirate fort, that is a submodel!
The advantages to the submodels are at least 4 fold.
1) They are easier to work with because they are smaller.
2) Submodels that are inserted into a larger model are a 'single piece', so it can be moved and rotated as a single unit.
3) If you use an item consisting of several pieces multiple times, you need only build it once. *like the torches on the Sentry Box
4) Once a submodel is inserted into a larger model, if you change something in the submodel, it will instantly be reflected in the larger model.
When you first enter MLCAD, there is a blank workspace.
From here you can drag pieces into your workspace and move the parts around to make the model.
Posted Image
Even a relatively small model like the Sentry Box can benefit from being built with submodels.
In the case of Phes's Sentry Box, I know I am going to want at least 4 submodels based on the reasons listed above.
I want the base of the model, or the actual Box itself except the roof, to be one submodel, the minifig to be another, the torches to be a third and the roof itself to be a fourth.
I selected the multipart menu and selected 'new model'.
Posted Image
MLCAD asks for a name and a description.  The submodels can have the same description, but must have unique names.
I entered a name and description and selected okay.  At this point I could have started making a submodel, but since I knew I was going to need several submodels, I just repeated the process and made names and descriptions for all the submodels I would need.
After all the names and descriptions for all submodels were created, I was ready to start building the submodels.  I needed to select the submodel to work on, so I clicked on the 'Multipart' menu, then selected 'Active Model'.  A list of all the submodels I made appeared.
Posted Image
I selected the first one, which I had named 'base'.
I then just dragged the pieces I wanted to make the base model.
Posted Image
Once I was done with the submodel, I selected 'Active Model' from the 'Multipart' menu list and went on to my next model.
Once I was finished with all the submodels, I decided it was time to assemble all the submodels into one single big model.  When I first started working, and selected to make my first submodel, I actually already had one submodel in my list.  You will see it was titled 'untitled'.  This is just the default/first model when you enter MLCAD.  If you never click on the 'Multipart' menu, or make another submodel, this will be the default submodel and your entire creation will be in this single submodel.  Since it was already blank, I decided I would use it to assemble all my submodels into one larger model.  You could create a new submodel from the 'Multipart' menu list and name it 'complete' or 'sentry box' or something, but since I already had a blank model to use, I just used it.
Posted Image
Here is the key to using Multiparts and submodels!!
Once I selected the the model that I was going to assemble all the submodels in, I scrolled down the left hand side of my parts list to the section titled 'Documents'
Posted Image
As you can see, all the submodels are there!
All I had to do was drag the individual submodels into the workspace as if they were a single part!
Posted Image
Here is Phes's box.
Posted Image
Now here is where all this submodel stuff becomes VERY useful.  Let's say that I wanted the roof to look different, but I didn't want to delete all the hard work just to find the new roof didn't wasn't what I wanted.  Since I have made submodels, all I have to do is delete a single piece, the roof submodel, off my finished model and make a new submodel of a new roof to add onto the sentry box.  If I don't like that roof, I can easily go back to the old one since it is its own submodel.
Here is a quick example of making a quick change to the roof using a new submodel.  As you can see over on the left, I still have a submodel for the old roof, so I could change it back whenever I wanted!  I called the new roof something intelligent like 'roof2', and inserted it into the finished model.
Posted Image
I hope you found this useful!
Note:
I am not going to export any of the models into picture form, because this is Phes's creation! Also, any instructions will also be up to him, I just wanted to show everyone the use of the submodel construction and its advantages!
MLCAD also had a brief tutorial which can be view by clicking the link below.
MLCAD Tutorial Link
Also additional parts for MLCAD can be found at the link below.  Make sure to follow the instructions to ensure the parts are added to your library!
Parts Tracker Library Link
Posted Image+Posted Image+Posted Image+Posted Image+Posted Image+Posted Image+Posted Image+Posted Image
See these MOCs and MORE in the Guilds of Historica!
Trian Burress fell in Nocturnus at the battle for Abyssian!
New Member? Read This | Questions? Need Help? Ask Here
Site Guidelines | Eurobricks FAQ | Visual User Guide | Tutorials
#2 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 20 February 2007 - 10:52 PM
Thank you so much for taking the time to create this tutorial Mr ZCerebus!  *y*
And for everyone else if you want to discuss the MOC used in the example then do it in the Imperial Sentry Box thread.
This thread should ONLY be used for MLCAD Pirate MOC related questions!!!
#3 Bonaparte
Bonaparte
  • Christmas Moose
    Member: 822
    Country: Belgium
Posted 21 February 2007 - 12:35 PM
I can't thank you enough Mr. Z.
This is exacltly what I needed to help me get started!
Want to find out more about our Reviewers Academy? Just click the logo.
Posted Image
#4 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 21 February 2007 - 01:04 PM
I've also added a link to this tutorial on the Tutorials Page of the Pirate LEGO Portal.
#5 ZCerberus
ZCerberus
    Member: 1043
    Country: USA
Posted 21 February 2007 - 08:13 PM
Now you can use this info on the Stockade file I sent you!
Unfortunately, the Harbor was my second MLCAD creation, so I didn't make as good a use of the submodels on the stockade as on some of my other creations.  The stockade only has about 10 submodels, the whole harbor has more, but the Sienna, for example, has 20 submodels by itself while the Arbiter II has 65(!) Submodels!!
Anyhow, happy CAD-ing!
#6 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 21 February 2007 - 08:52 PM
I followed the tutorial and now I can do sub models!  So head over to the Imperial Sentry Box thread and checkout the end result.
#7 Bonaparte
Bonaparte
  • Christmas Moose
    Member: 822
    Country: Belgium
Posted 21 February 2007 - 11:44 PM
I also made a version of the Phes-Sentry-Box with MLCad.
This is really an excellent way to learn how to work with the program.
Tomorrow I will import the Stockade file which Mr. Z provided me some time ago.
Just wanted to inform you that the link is incorrect.
Posted Image
#8 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 22 February 2007 - 12:03 AM
Aaaaaaargh the bleedin buzzards!  You're right Mr Bonaparte!  And its been fixed in my original post and in your reply post. You're on the ball!  Its a wonder you're not a Moderator around here :-D
Anyway, are you going to post your version of the Sentry Box?
#9 Bonaparte
Bonaparte
  • Christmas Moose
    Member: 822
    Country: Belgium
Posted 22 February 2007 - 12:29 AM
I don't plan to post my version since it is exactly the same as yours  :-D
I'm just using this to learn MLCad. Now I'm struggling to extract the building instructions for the Sentry Box (I hope that is possible).
I can already get an image per submodel, but these are not really instructions. I guess I better read the MLCad manual first...
Anyway, it will be for tomorrow. I'm going to bed.
Posted Image
#10 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 22 February 2007 - 12:49 AM
You should post your version, just like Phred posted his version as its interesting to see other's interpretation.
#11 ZCerberus
ZCerberus
    Member: 1043
    Country: USA
Posted 22 February 2007 - 02:32 AM
There are "Step" buttons in the MLCAD program.  I personally have only used MLCAD to design the models, and haven't really experimented with "instructions"
The button for a step is the little 'S' with the arrow next to it...
Hmm... maybe you SHOULD read the manual instead of listening to me!
#12 Bonaparte
Bonaparte
  • Christmas Moose
    Member: 822
    Country: Belgium
Posted 22 February 2007 - 11:35 AM
I will read the manual and listen to you  ;-)
Just did a quick experiment during my lunch break with the "steps".
Now I get the instructions the way I want them. So thanks again Mr. Z.
Printed the official manual. I'll read it tonight during my train trip home.
Posted Image
#13 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 22 February 2007 - 08:50 PM
Yes, reading the manual before using the problem is the probably the most important and overlooked step to learning it!
View Postbonaparte, on Feb 22 2007, 10:35 PM, said:
Just did a quick experiment during my lunch break with the "steps". Now I get the instructions the way I want them. So thanks again Mr. Z.
We'll need a tutorial for the steps soon!
#14 Bonaparte
Bonaparte
  • Christmas Moose
    Member: 822
    Country: Belgium
Posted 22 February 2007 - 09:51 PM
Here is the direct link to the MLCad Tutorial.
It is only 7 pages and you can learn everything while building a small space MOC.
Explains also the use of submodels (explained a bit different) and how to use the steps for making instructions.
It's interesting to know that the steps can by added at any time. Even when the model is finished.
And you can see the different steps while in "View Mode" (normally you are in "edit mode").
MLCAD Tutorial Page
Posted Image
#15 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 22 February 2007 - 11:37 PM
Now where's that Imperial Sentry box you've been telling us about, Mr Bonaparte?  X-D
#16 Bonaparte
Bonaparte
  • Christmas Moose
    Member: 822
    Country: Belgium
Posted 22 February 2007 - 11:48 PM
Here is a small picture of it. But as I mentioned, it is not different than yours.
Posted Image
Posted Image
#17 CopMike
CopMike
  • Making L look good
    Member: 148
    Country: Sweden
Posted 22 February 2007 - 11:49 PM
Hi guys!
One fast (maybe silly :S) question: you write about MLCAD but Ive only come across LDRAW, is that the same stuff or what? I can see that they have different names  :'-) but when I read some topics I get it mixed up!
copmike /newbie CADdie
Posted Image
#18 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 23 February 2007 - 01:55 AM
Its a work of art!  I couldn't have done better if I'd made it myself.   :-D
The only silly questions are the ones you DON'T ask!  I downloaded MLCAD quite some time ago but when I did so, I download a complete package which included LDRAW, MLCAD POVRAY and several other programs.
I think I got it from the official Mike's LEGO CAD Webpage.
#19 CopMike
CopMike
    Member: 148
    Country: Sweden
Posted 23 February 2007 - 09:28 AM
Thanks for the answer!
This is the page that I used to but here the confusion starts :S! Is LDRAW & MLCAD to different programs? Ive used LDRAW with LBU & POVRAY but the parts that are in the LDRAW libary isnt nothing to what you have showed, mostly minifig wise. Is the another partslibary than LDRAW & Parttracker?
CAD On
copmike
Posted Image
#20 ZCerberus
ZCerberus
    Member: 1043
    Country: USA
Posted 23 February 2007 - 02:33 PM
CAD On
Ah, I can see the confusion...
Here is the thing, LDRAW is also a LEGO modeling program.  It is not as advanced as MLCAD.  MLCAD used the LDRAW parts library, but added the additional abilities to be able to view the creation from multiple angles, add minifigures and hoses and the like.  Since MLCAD is designed to used most of the LDRAW parts, that is where the confusion may be setting in.  Basically we are using MLCAD, which is an off-shoot of LDRAW.  MLCAD uses LDRAW parts, in fact one of the very first things you have to do after loading MLCAD is link it to the LDRAW library!!, so that is why you see the LDRAW parts even though you are using MLCAD!
Anyhow, you can download all the unofficial parts as well as the official parts.  The unofficial parts will add the Imperial torsos at least, but there are still parts missing, even after getting the whole unofficial parts library.  Some can be found in an uncertified form, but might not be perfectly accurate!  If you do download all the parts, make sure to follow the instructions given on the page to ensure the new parts will be added to the library!
#21 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 23 February 2007 - 09:56 PM
Where do we download these "unofficial parts"?
And what about official parts like the Redcoat Imperial Guard flag (as pictured in ZCerberus's signature) which for some reason has been excluded from MLCAD?
#22 ZCerberus
ZCerberus
    Member: 1043
    Country: USA
Posted 23 February 2007 - 11:58 PM
Here is the links to the parts library:
Parts Library
Even with the library though, there are still some parts missing...
Red Imperial Flag, Door frane for jail door, rowboats and a few other random pieces I have wanted!
#23 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 24 February 2007 - 07:07 PM
View Postbonaparte, on Feb 23 2007, 08:51 AM, said:
View PostZCerberus, on Feb 24 2007, 10:58 AM, said:
Both these links should probably also be added to the first post of this thread.
#24 ZCerberus
ZCerberus
    Member: 1043
    Country: USA
Posted 24 February 2007 - 07:34 PM
Well Since I have edit powers on my own first post... maybe I will!!... or will... haha
#25 Mister Phes
Mister Phes
  • WordPress Wizard
    Member: 273
Posted 24 February 2007 - 07:42 PM
You could leave it for Mr Tiber to do.  He'd love the extra work :-D
