Pirates! (gaming)
#1
Posted 25 January 2007 - 10:44 PM
I was wondering if there are any rules out there for lego pirates.
I do know of Evil Stevie's Pirate game and have been there quit a bit.
Though, I am wondering if there are any other rules or games that others have made for having ship to ship combat. Or maybe even just mini-fig to mini-fig combat rules.
My brother and I are looking to have all our vessels go against each other and see who the better captain is.
Arrrrrr! *pirate*
Thanx,
Phred
Edit:
List of Pirate RPG Threads:
Pyrates the Game
My Fleet is Complete
Evil Stevie's Pirate Game
Big minifig illusion scale ships and ESPG
Nice Pirate website for Reference:
http://www.thepirate...irate ship.html
Read the site guidelines | Index of helpful tutorials | Eurobricks FAQ
Pirates don't hunt for treasure. They bury it- I mean we bury it. - Captain Kirk
#3
Posted 26 January 2007 - 12:47 AM
EXO-CHAMP, on Jan 25 2007, 04:50 PM, said:
If I had some pirates I'd make a game for it myself, but pirates aren't easy to come by these days (guess I don't have to tell you that).
Good luck with your search...
Is thisthe Brickwars website you were referring to?
I'll have to check it out. Thanx.
I don't have to worry about getting pirate sets that much, because i've still got all mine from when i was a kid.
Phred
#7
Posted 29 January 2007 - 06:32 AM
EXO-CHAMP, on Jan 26 2007, 12:51 AM, said:
I think i found what i'm looking for there too.
Mr Tiber, on Jan 26 2007, 02:42 AM, said:
Well technically the Xebec is mine since it's made with my bricks. X-D
I've got the Xebec, my Junk, ,armada Flag ship, la Dame du Loup, a vikiing long boat. My brother has about 10-11 Lego Pirate Ships ranging in size from the CrossBoneClipper ( :-| :-X *wacko* :'-( *n* *n* *n* ) to the BSB.
#9
Posted 01 February 2007 - 02:39 PM
Mr Tiber, on Feb 1 2007, 03:17 PM, said:
I already have a rule: Minimum distance when using normal LEGO cannons is three studs.
It seems the players have to be in the same physical location. Is this always needed for these games?
Want to find out more about our Reviewers Academy? Just click the logo.
Got Questions? Need help? New member?
Please read the Members Guidelines and check the Tutorials Index
#10
Posted 01 February 2007 - 04:14 PM
I geuss it is a bit difficult to do this online...
I also read the maximum broadside is 5 guns in the rules of ESPG, is this true? If it is, I'm not interested in the game...
#11
Posted 01 February 2007 - 04:35 PM
Here's another lego pirate game i found.
It's called Dread Stephen's LEGO® Pirate Wars. Click here:
The hull points on this one goes by stud length of the ship, rather than hull pieces.
I'm currently making a spread sheet on Excel to compare hit points and attributes of my brother's and my vessels with Evil Stevies and Stephan's games.
#13
Posted 01 February 2007 - 05:05 PM
Mr Tiber, on Feb 1 2007, 10:45 AM, said:
Most of the MF's don't even have head gear too. Definetly made for gaming and not for display.
Edit:
To start off, I think the mass of the ship w/o cannon and crew should be the hit points or hull factor.
Reason being is that if a MOC is made with more bricks per length than others, it should have a higher hull factor.
I think having 3 studs between cannon is fine :-| .
Phred
#14
Posted 01 February 2007 - 05:50 PM
Mr Tiber, on Feb 1 2007, 05:45 PM, said:
I will shoot this ugly MF into pieces in no time.
#16
Posted 02 February 2007 - 09:05 PM
Mr Tiber, on Feb 1 2007, 08:32 PM, said:
Thanks for correcting me *y* :-D :-D :-D
#17
Posted 04 February 2007 - 01:35 PM
I believe we have a member who made this up, I also believe he made some of the ships on that site... And he is called UKDevilz...
#18
Posted 23 February 2007 - 07:42 PM
It'll definetely be a lot easier when the spread sheets do all the math automatically.
I've already figured out how to have dice on the spreadsheet:
=RAND()*(6-1)+1 is a six sided dice. Then set the cells to 0 decimal places, and you've got yourself an excel dice. :-)
So instead of purchasing lots of 1D6 dice and wierd dice (1D4 to 1D20), I just have to type a little bit of a different # and i have all the dice i need. *pirate*
Hopefully when i'm done with the spread sheet, all you have to do is type in (numerically) what you want to do and everything is done automatically. How many troops you lost, how far you sailed, if your ship sinks etc.
This should make it really easy for others to roleplay too.
Does anybody know how to post a spreadsheet in excel format so that others may download the spreadsheet and use it or critique it? Or a website i can upload it to to be availible to download?
Thanx,
P
#19
Posted 24 February 2007 - 02:31 AM
To me it's always easier and more logical to turn a "gaming area" into a grid. It's the foundation of many games after all. (literally! ;-)) The rules would be something like this:
Each ship sits on a single grid (In this case micro-ships and whatnot are the best solution. If you want to be stubborn you could make GIGANTIC squares. :-P ). The objective of the ships are to either sink each other or board each other. The only way to board another vessel is to grapple it of course, so the ships will only be able to do this when they're on aligned squares and one of the members has released the grapple. The ships can only travel horizontally or vertically, NOT diagonally.
There are three "sail tokens"--> "Right", "Left", and "Forward" or "Up". At this point I'm not exactly sure how the players would decide how many tokens they should each have during a "turn". I guess it could be calculated on a ratio of men to sails. Ideally each ship would be sufficiently manned, and every loss after that would slow the production rate of these "sail tokens".
Then there are the cannons: Like the above ratio of men to sails, there should also be an established ratio of men to cannons. The less men you have, the longer it takes to load cannons. How long it takes to load a cannon is up to you, I suppose.
The next part requires an hourglass or a timer of some sort: During an interval of thirty seconds or so(whatever you prefer) each player decides what "sail tokens" he wants to use, aka what direction the ship will go. These should be in a vertical sequence like so:
A
B
C
D
If you want to release a grapple or fire your cannons then dot the left or right side of the specific "token piece" for when you want to enable that move. And to clarify, these moves will be based on their sequence. If "up" is first move on the vertical sequence, then that's the first move you make. Four to eight moves (anything within reason) will then be acted out on the grid. Both players should move their ship in sync with the other to avoid confusion. (In other words, both ships move, then stop, then move, etc.)
I've never actually tried playing this with LEGO ships, but then again my house isn't spacious enough for such an event. I might have overlooked something, in which case feel free to call me out on it.
#20
Posted 24 February 2007 - 06:06 AM
A
B
C
D
do you have more exhaustive rules to go by or the original word doc? Feel free to email or pm me a copy *y*
I was thinking of having grids set up with lots of masking tape or something on the floor. but i like seeing other ideas to use what i like and think is realistic. ;-)
Thanx,
P
#21
Posted 25 February 2007 - 09:13 PM
Sea Battle
Here's an idea of what I was talking about (there's another picture in the above link, too):
#22
Posted 26 February 2007 - 04:17 PM
Berry Syedow, on Feb 25 2007, 03:13 PM, said:
Heh, heh, you must have a LOT of space if you can do that!
Well some room at my brothers, but more than enough for miniature versions of our ship ;-)
#23
Posted 12 April 2007 - 05:15 AM
Islanders +3 throw spear for others 1d8 only 8 hits +10 yds for others max 10yds
Indian +3 throw hatchet for others 1d8 only 8 hits +10 yds for others max 10yds
Cavalry +2 with pistol
Samurai/ninja 6 attacks per turn with sword +3 attack, move+2 studs for others 2 attack per turn w/ sword
Marines +3 attack with rifle 1 per turn +1 other weapons others one shot in 2 turns
Admiral +1 attack with sword +2 with guns and double attacks per turn
Officers and soldiers +1 attack
Boys can’t use rifle, spear, throw hatchet, -2 with all weapons -2 studs per turn to move
minifigs can mave 10 studs per turn
Duke
#24
Posted 15 April 2007 - 05:30 AM
It's not perfect, but it's the best i've figured out so far. :-)
To get this formula i used the attributes of real ships to figure it out on excel graphs.
Ok...
It's kind of rough right now.
But the ships i've figured out so far is that
the Armada flag ship has a top speed of 9.2 knots
the Emporer's Ship has a top speed of 4.3 knots
my Junk
**Edit:
my Xebec
and my Dame du Loup has a top speed of 17.6 knots.**
The formula is partially a multiplication of the length to beam ratio and the sail area to dispersement ratio.
The real ships used were the:
HMS Victory
USS Constitution
Flying Cloud
HMS Surprise
some ship called the "Albert Leo Schlageter"
and the USS United States.
I'll probably post the exact formula when i've simplified it to a formula that already figures in differences in scale and converting to and from english and metric.
P
Edit:
Hey Duke, you forgot to mention that one turn is roughly equivelent to 30 seconds in real-life.
#25
Posted 27 April 2007 - 02:52 AM
Instead of using a linear formula I'm using an inverse tangent function where a ship has to be very very efficiently built to have a top speed of 20 knots or more.
Here's the formula:
(atan[(L/B)*((SA)/(M))*0.3024562649])*16=(speed)
atan is the inverse tangent in radians (atan is what needs to be typed to work in Excel).
L is the length of the ship in length (not including the bowsprit).
B is the beam or width of the lego ship (not including fancy details on the sides).
(doesn't matter what unit is used to measure length and beam, but they must be measured in the same units like studs, cm, in, etc.)
SA is the sail area of the ship in cm squared.
M is the mass of the lego ship in grams.
(any questions pm me or post on here :-) )
Here are the speeds (in knots) of the official released sets done so far:
(if not in bold, then i don't have exact numbers yet)
Row Boat w/ sail: 18.2 knots
Row Boat w/ 2 sails: 20.2 knots
Imper. Trad. Cutter: 14.9 knots
Emporer's Ship: 6.5 knots
Crossbone Clipper: 6.5 knots
Imperial Flagship: 16.2 knots
Armada Flagship: 11.5 knots
Carribean Clipper: 11.1 knots
Viking Long Boat: 16.6 knots
Black Seas Barracuda: 12.5 knots
Here are the speeds of my MOCs:
Chinese Junk: 14.6 knots
HMS Charlie: 12.6 knots
Xebec: 20.7 knots
Dame du Loupe: 17.0 knots
Will be editing more finalized details later.
P
Reply to this topic
